ok, i'm trying to find a free to $20 program that will let me combine multiple ~30min avi files--episodes of a tv show--with a basic customized Menu, with sub-menus for each episode...which allows me to set chapter points, as a sub-menu button. The points i wish to set will be 1) opening credits 2) first half 3) second half 4) closing credits.
DA
GUI for dvdauthor is one, DVD Author GUI is another. Both are freeware. You should be aware if you want to do some fancy effects, you may need to do part of them with other programs. But both the programs mentioned have guides at the bottom of their toolpages. Even with pro programs, other programs are used to do the menus, etc. But give those two a try. You can do professional work with them. Just a bit of a learning curve.
And welcome to our forums.
EDIT: You mentioned editing. You do that with a video editor, not a authoring program. Authoring just creates the DVD format. Look to the upper left on this page for 'WHAT IS' DVD for the DVD specifications, format and structure. -
Thanks for all of your help! I ended up using GUI for DVDauthor, as that the Menu creation was quite easy. I still haven't figured out how to create animations for the main menu, but the chapter points came out fine (thankfully the program animated those for me :P ). I used Super DVD Creator to capture the images I wanted to use for the title image. I used Any Video Converter to convert the avi to mpeg (ntsc format).
DA
Few n00b questions regarding backing up blurays ..
By ahmadka in forum Blu-ray RippingReplies: 0Last Post: 20th Apr 2011, 12:49 -
Does arcsoft total extreme have a 3 hr maximum limit for authoring?solved??
By yoda313 in forum Authoring (Blu-ray)Replies: 0Last Post: 11th Mar 2011, 13:41 -
Live TV streaming to Web via VLC - Total n00b, so go easy on the flames...
By br3nton3 in forum Newbie / General discussionsReplies: 9Last Post: 2nd May 2009, 17:24 -
2 questions about DVD authoring
By ihmcjacky in forum Authoring (DVD)Replies: 23Last Post: 5th Jul 2008, 05:21 -
Few questions about authoring a PPV to a DVD
By phatk9999 in forum Authoring (DVD)Replies: 4Last Post: 30th Jan 2008, 22:14
