First off, this might not be the correct section but seemed the most relevant.
I am converting an .mkv video file to VOB using DVD Flick. I keep almost all the standard settings and leave the audio encoding set to auto and it chooses 5.1 Surround (I am able to specify mono, stereo or 5.1). When i look at the source audio track it tells me its: AC3 CBR, 48000 Hz, 6 channels. The conversion completes without any errors. I am able to play the movie fine with both PowerDVD and VLC media player.
The problem I am having is when i go to watch the movie on my DVD player. There isn't any audio.
I have a Yamaha RX-V661 AV Receiver and a Sony RDR-GX330 DVD player.
I'm not sure if this is a problem with my DVD player having a problem or with DVD Flick not converting .mkv format correctly. Thanks
It might not convert the audio.
maybe you could recommend a good converter for .mkv files that is of superb quality since i can't seem to get DVD Flick to work correctly.
EDIT: or is there something i'm missing. I've gone through all the settings on my standalone DVD player but nothing i change does anything. I know there is audio because when i play the DVD on my computer there is audio.
Ripping DVD with sub to be played on media player.
By hanugro in forum DVD RippingReplies: 4Last Post: 12th Feb 2010, 06:10 -
SD DVD Played on Blueray Player
By wulf109 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Aug 2009, 08:36 -
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 12:56 -
making a video cd which can also be played on DVD player
By d_razaq in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2007, 17:09 -
no audio when played on dvd player
By soccer in forum AudioReplies: 6Last Post: 4th Aug 2007, 18:18
