I've got a few PAL VHS old tapes that need to be converted to NTSC tapes/DVD. Can anyone teach me the easiest and cheapest/free way to get the job done?
Thanks a lot!
Mike
This cannot be done for free. You will either have to pay someone to do it or buy some equipment and do it yourself. To be blunt, I'd advise you to pay someone to do it. If you have "a few PAL VHS tapes" as you said, it's not worth spending hundreds of dollars on the equipment to do it. Also, no offense but if you have to ask that kind of question, you're probably not up to the task of doing what is necessary, even if you have the right equipment.
Major cities should have various local companies that can do this kind of work for you. I'd expect them to charge you maybe $20-30 per tape to do it. It's also possible to find companies online who will let you mail tapes to them, but I have no personal recommendations to make. -
I handle a lot of PAL>NTSC VHS conversions, doing one right now on another system in fact.
Indeed, it does take special hardware, and then beyond that, the conversion process itself is best performed with some semi-complex methods, and those do involve payware.
The cheapest would be to send it somewhere. I've never come across a local walk-in store that handles PAL>NTSC with any sort of quality (they use really crappy cheapo hardware methods), so your best bet is to find a service online to mail the tapes to, that uses a quality method.
As an example of the software-side work, see http://www.digitalfaq.com/guides/video/convert-pal-ntsc.htm
A modified workflow is used when VHS is the source, as opposed to the digital source (DVD, for example) used in that guide.Want my help? Ask here! (not via PM!)
Are these commercially recorded tapes? If they are, perhaps NTSC versions are available. In that case, the "easiest and cheapest" method would be to buy them.Originally Posted by manhnt
If they're home-recorded, or NTSC versions are otherwise simply not available, then your best option might be to do a deal with lordsmurf.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Newbie needs to convert NTSC VHS tapes to PAL DVD
By mcullen8320 in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2008, 14:51 -
Pal S-VHS to NTSC PC
By Jerry1964 in forum Capturing and VCRReplies: 14Last Post: 19th Aug 2008, 09:50 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
