Probably a dumb question on this application.
When should Colomatrix be used?
Some time ago someone told me that when converting from HD to SD with avisynth I should add this line:
ColorMatrix(Mode="Rec.709->Rec.601")
In fact, when checking on on AvsP things change a little, mostly in contrast I'd say, when I switch between using Colomatrix or not.
Should I use it or not?
That would depend on what you're going to do with the footage............
If for instance you are going to edit the footage in Vegas, then you'll have to convert to RGB PC.709, because Vegas only works in RGB. If you are going to encode to dvd via TMPGEnc, then you'll need to convert to RGB REC.601 because that's what TMPGEnc will produce. If you are going to encode to H.264, then you can leave it alone.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
avi signpost to h264, colorspace and colormatrix
By codemaster in forum EditingReplies: 4Last Post: 20th Apr 2012, 10:49 -
setting the correct colormatrix in x264
By codemaster in forum Video ConversionReplies: 1Last Post: 2nd Mar 2012, 22:14 -
colormatrix problem in auto gk 2.55..
By kapatralla in forum DVD RippingReplies: 1Last Post: 31st Jan 2010, 01:53
