Hello all,
I work in motorsports and I have 2 cameras on the truck (yes race truck...)
They record in MP2 and using mediainfo i could make that the audio is as follows :
Audio
Format : MPEG Audio
Version du format : Version 1
Profil du format : Layer 2
Durée : 14mn 40s
Type de débit : Constant
Débit : 256 Kbps
Canaux : 2 canaux
Echantillonnage : 48,0 KHz
Résolution : 16 bits
Delai par rapport Vidéo : -241ms
Now i'd like to extract the audio from 1 video, edit it and repaste it in the video (and in the other one because i have sound on only 1 camera....)
Thanks for the help
What's the container? MPG? TS? M2TS? MP4? MOV? AVI? There are many muxing/demuxing tools.
Hello
The extension is MP2 and apparently it's MPEG PS (and not TS)
Here's the full media info, thanks
Nom complet : G:\PiWorld\Data\2009\R6 Nurburg\vids2\07.26-19.05.105\1FFF07D.mp2
Format : MPEG-PS
Taille du fichier : 715 Mio
Durée : 14mn 40s
Débit global moyen : 6 811 Kbps
Vidéo
Format : MPEG Video
Version du format : Version 2
Profil du format : Main@Main
Paramètres du format, Matrice : Par défaut
Durée : 14mn 40s
Type de débit : Variable
Débit : 6 082 Kbps
Débit nominal : 4 096 Kbps
Largeur : 352 pixels
Hauteur : 288 pixels
Format à l'écran : 4/3
Images par seconde : 25,000 Im/s
Colorimétrie : 4:2:0
Type d'image : Progressif
Bits/(Pixel*Image) : 2.400
Audio
Format : MPEG Audio
Durée : 14mn 40s
Débit : 256 Kbps
Canaux : 2 canaux
Delai par rapport Vidéo : -241ms -
TsMuxerGUI can demux from the .MPG (MPEG program stream) container. But it can only mux them into .TS or .M2TS containers. TMPGEnc Free's mux/demux tools should be able to handle both mux and demux with the .MPG container. Audacity (free audio editor) can import from MP2 audio, either from a demuxed file or from an MPG file.
Ok, thanks for the help, DGindex did the trick, I can get the file in .mp2 format with just the audio.
Now i need to be able to add audio to an .mp2 MPEG-PS file to be able to paste my audio file on my second video file (which has no audio...), I'ved looked in DGIndex but apparently there is not option to mux audio into a file, just extract from it, can you point at a program that would allow me do mux my extracted audio file into the other video file ?
Once I've finished this audio adding I want to encode the final file (video+audio) in .mp2 MPEG-PS format into H264 or something like that but I'll post in the video section
Thanks again -
You can try muxman or imagompeg-muxer to mux the audio & video into MPEG-PS
how to convert mp2 audio to lpcm?
By gareth41 in forum Authoring (Blu-ray)Replies: 9Last Post: 21st Oct 2011, 13:47 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
Extract .m2v and .mp2 files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2010, 12:42 -
Merging mp2 video and audio - on a MAC
By Carder123 in forum Video ConversionReplies: 0Last Post: 26th Apr 2010, 06:24 -
MP2 audio with LAME?
By RogerTango in forum AudioReplies: 7Last Post: 3rd Nov 2009, 22:28
