I encoded some VCDs using DVDX/TMPGENC, and burned them on proper CD-R (Sony) using WinOnCD.
They work fine on the PC, but when viewed on Toshiba SD-210, I get either some blocky scenes, or some interuptions in the display.
The sound is always in synch though.
1. Is is know weakness of such DVD players ?
2. Should I use other CD-R makes ?
3. It is probably not the encoding, nor the burning since the PC reads them fine, right ?
Many thanks for your help.
Results 1 to 1 of 1
Toshiba Camileo H2O and Osprey 210 capture card?
By Amanda28 in forum Capturing and VCRReplies: 1Last Post: 17th Nov 2009, 14:12 -
Asus PCI PVR-210 FM drivers can't be found for XP ?
By MidnightMike in forum ComputerReplies: 1Last Post: 22nd Jan 2009, 10:05 -
Windows cannot see VCD, directory blank, but plays okay?
By ianlin in forum Authoring (VCD/SVCD)Replies: 8Last Post: 3rd Oct 2008, 16:17 -
VCD plays but has no audio
By rockydogg97 in forum Newbie / General discussionsReplies: 1Last Post: 12th Feb 2008, 03:07 -
Bilingual VCD plays both languages in Media Player Classic!
By cordeliamars in forum Authoring (VCD/SVCD)Replies: 2Last Post: 27th Aug 2007, 13:25
