  1. I have about 26 mp4 files that i got from a friend. Each of them is about 1 minute long. They are numbered sequetially. I can play them indivdually in VLC but I would like to combine them all to one clip.
    I tried YAMB 2.1.1 beta and it did combine them all into on file but when I tried to open that file in VLC I got 26 vlc windows. NOT at all what I wanted.
    Is there any solution.
    For information I am using windows XP SP2.
    I guess you choosed editing in yamb and not creating mp4?
    Or else use avidemux and append all mp4s and save as a new mp4.
  3. Originally Posted by Baldrick
    Ok I will try combine in yamb with must 3 of the files. I will get back to you in 10 minutes
  4. Well I found out that i need to click the down arrow next to "Output" and check the box that says VFR Creation.
    I will let you know my results on the total file.
