Using eac3to source.dts target.wav ResampleTo44100 produced the 6ch wav I wanted but I noticed in mediaInfo it displays "MIDDLE" L R LFE, instead of "SURROUND L R LFE" like I usually see in 5.1 wav files.
Can anyone tell me why and is there any difference, is this just simulated 5.1 Suround Sound someone created with something like VST Effect for Stereo to 5.1.?
https://forum.videohelp.com/topic291881.html?highlight=middle%20surround
Is this not the same company that is trying to incorporate HDMp3 as well?(lossless MP3 & Surround )
http://www.macworld.co.uk/digitallifestyle/news/index.cfm?RSS&NewsID=25467
Thank you.Code:Complete name : 44100k 24bit.wav Overall bit rate : 6 350 Kbps Audio Format : PCM Codec ID : FFFE Codec ID/Info : Extensible Duration : 2h 17mn Bit rate mode : Constant Bit rate : 6 350 Kbps Channel(s) : 6 channels Channel positions : Front: L, C, R, Middle: L, R, LFE Sampling rate : 44.1 KHz Resolution : 24 bits
Results 1 to 1 of 1
stereo downmix: surround vs surround 2
By codemaster in forum AudioReplies: 7Last Post: 29th Aug 2012, 12:06 -
Capture megavideo from the middle of the film
By TTY in forum Video Streaming DownloadingReplies: 5Last Post: 2nd Jan 2012, 14:32 -
missing subtitles in the middle of the movie
By steapien in forum SubtitleReplies: 5Last Post: 13th Dec 2009, 22:17 -
How to add a scene in the middle of a movie
By L3PA in forum Authoring (DVD)Replies: 14Last Post: 16th Apr 2008, 05:47 -
shutdown in the middle of ConvertX
By doodoobrova in forum Authoring (DVD)Replies: 3Last Post: 8th Feb 2008, 19:32
