    Jul 2009
    I need to convert different files to DVD (avi, MKV, ogm) sometimes with multiple audio and/or subtitles.
    I currently have Xvid4PSP and Nero.
    Do I need something else or can I use them? How do I use them (for this)?
    Sorry I'm alittle new to all this, I've made a couple DVD backups with ISOs but that was easy. I've never had to use other video files (TS files I think... right?)
    Any help would be greatly appreciated.
    Use DVD Flick(free) or ConvertXtoDVD.
    You can also use nero vision but it might not support all your video sources.
    Jul 2009
    Thanx for the help.
    Sorry it took me so long to reply (internet went out).
    I tryed using DVD Flick and it worked great. real easy to use.
    But after converting I could only fit about an hour of video on a DVD.
    Do I need some kind of compression software or something?
    canada
    You need to learn about bitrates so you can put 2 hours of video on a 4.38 gb dvdr.
    May 2003
    Cleveland, OH, USA
    Yup... and you could always use a dual-layer DVD-R if you don't want to sacrifice quality.
    Jul 2009
    Awww, dual-layer=expensive and learning is hard
    Thanx for all the help :P
