Does anybody know if you can display your Internet Explorer favorites in Outlook 07? Is there a way I can access those links in outlook so I don't have to open up my browser and access my favorites on there? Apparently this used to be possible in previous versions of Outlook, and I can't figure out how to do it in Outlook 07 running windows vista. Any help is appreciated, thanks!
I don't know about Outlook (never used it), but you could always enable the Favorites on the Start menu (right-click on Start menu > Properties > Start Menu tab > Customize... (the top one) > scroll down to 'Favorites menu' and place a checkmark in the box > click OK for everything). Then, if you need to, say, copy a Favorite into an email message, you might be able to go to the Favorites menu in the Start Menu, find the Favorite you want, and drag it onto the email message.
If cameras add ten pounds, why would people want to eat them? -
Favorites in Outlook 2007 is under shortcuts in the left window
You can create a new group, or shortcuts. You can drag and drop from IE into the group.
However, by default, it will open the URL in the right window, inside Outlook -
Stiltman, that seems to have done the trick! Thanks to you and Ai for your input!
Internet Explorer 8 Keep Crashing
By Squid_uk in forum Newbie / General discussionsReplies: 6Last Post: 27th Oct 2009, 18:44 -
Internet Explorer Runtime Error
By KingSeti in forum ComputerReplies: 14Last Post: 26th Feb 2008, 12:35 -
something wrong with internet explorer
By ssaamm in forum Newbie / General discussionsReplies: 9Last Post: 5th Oct 2007, 08:28 -
How can you get rid of Internet Explorer?
By video_enthusiast07 in forum ComputerReplies: 8Last Post: 10th Jun 2007, 19:05 -
Internet Explorer and Mozilla Firefox
By kimco52 in forum ComputerReplies: 19Last Post: 10th Jun 2007, 05:06
