I tried searching the archives and articles on this site and only got more confused. What's the most painless (or least expensive) way to convert the old HD DVD formatted discs to the new Blu-Ray?
The "easiest" way I have found is to do a realtime dub with the hauppauge hd pvr 1212.
I have the xbox 360 hd-dvd add on device. What i have done is a realtime dub via component cables and fiber optic audio out to record to m2ts files. I get full hd this way. Whatever my xbox outputs is recorded in the hdpvr (though I don't know for sure if the hauppauge hd pvr 1212 does full 1080p - certainly 1080i - the xbox 360 does 1080p of course).
This is realtime dubbing so you get a fully useable file after its finished playing.
Ripbot264 also works. I have done that for some of mine also. However it is time consuming. First you have to have a hd-dvd rom on your computer and rip with anydvd hd (must be the high def version). Then you can convert to mkv with ripbot264 as wulf109 suggests.
Converting to 1280x720 with 5.1 on my amd 2.7ghz dual core pc takes about 16 hours. THats a good bench mark to look for with a 2 hour movie and no extras.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Why would you want to re-encode the video, when HD-DVD codecs are compatible with Blu-ray ones (except mpeg audio)?
You can use multiAVCHD and load your FEATURE_1.EVO (or any other .evo file), then you'll get Blu-ray structure (or AVCHD) to burn/play on your blu-ray player / ps3.
DeanLaugh and the world will laugh with you. Cry and you will be alone
conversion blu-ray to dvd that select audio/subtitle tracks as requirement
By wisitch in forum Video ConversionReplies: 4Last Post: 25th Nov 2011, 08:04 -
faster blu-ray to dvd single layer conversion
By Steve(MS) in forum Blu-ray RippingReplies: 11Last Post: 10th Aug 2011, 22:02 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 23:04 -
Blu Ray conversion to DVD??
By mrswla in forum Blu-ray RippingReplies: 2Last Post: 26th Mar 2009, 18:54 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
