    Aug 2007
    Im converting avis into mpgs for authoring a dvd
    im using TMPGEnc to convert the avis, whats the best setting to use for playback on televisions?
    16:9?
    or isit best to keep it as the suggested settings of 1:1 vga?
    thanks in advance for any help...
  2. AVI sources will most often be 1:1 VGA. But the best setting is the one that matches your source. For output select 4:3 or 16:9 whichever most closely matches the source's display aspect ratio.
    Aug 2007
    how do i check the sources display aspect ratio, i cant find anything in properties?
  4. GSpot will tell you the source's aspect ratio.
