After weeks of working perfectly, ImgBurn now stops part way thru a DL burn - at points ranging from 50 to 70% completed. The problem has occurred with The West Wing, Season 1 and Deadwood, Season 2 (but only Disc 4, the others were fine when done a few days back). In ImgBurn, I'm selecting the break point with a green star altho it sometimes seems to me that it's too close to the end - but then I don't fully understand what part of the files I'm looking at in the break-point window.
I then can't close ImgBurn - it just stays there. I mostly have to force a close by forcing a quit on VMWare Fusion (I'm running XP under Fusion on a Mac). Is there an easier way to force a close?
I've been having shut-down problems (hangs part way thru the process). I haven't installed any new hardware or software in the interim period. So far, I've tossed about 10 Verbatim DL discs. Any suggestions?
	No, I haven't. I'll try a DVD5 and a DVD9 and see what happens. I may well need to post the log. Thanks.
 In the interim, I'm uninstalling and re-installing VMWare Fusion and starting with a brand new boot of XP in an attempt to eliminate problems like non-shut-downs.
  Blocks after burning ImgburnBy Russo in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2011, 20:31
  SVCD2DVD and then burning with imgburn failsBy baby2003 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2010, 14:57
  Burning with ImgburnBy Ronny G in forum Authoring (DVD)Replies: 7Last Post: 16th Mar 2008, 19:37
  burning error using imgburn DVD9By mvp in forum Newbie / General discussionsReplies: 6Last Post: 4th Nov 2007, 01:04
  ImgBurn burning questionBy yogart in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 02:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
