Hey there
I have about 25 FLV vids but they have .exe at the end and I can not find a converterneed to convert to DVD
I have tried AnyVidConverter,Xilisoft converter,wondershare vid converter
Can any of you great gurus help me here!! promised a friend that I would deliver today as he is laid up in bed for 6 months
Cheers
The first thing I would do with any video file that comes as an EXE is delete it.
if they are just FLV videos with a .EXE extension you could simply rename them with the correct extension. However with a .EXE i'm guessing this is not the case and its not actually what you think. I wouldn't run the files, I'd definately follow jagabo's advice and delete them.
If on the other hand these are files that you've had for a while and do play as videos on your PC (not sure how but maybe you've got something setup to play them whilst ignoring the assosciated extension, then post the MediaInfo here so we can have a look at what you're really dealing with. saying 'FLV with .EXE at the end' doesn't give anyone any where near enough information to help you.
Going back to the original point though....if you havent run these videos yet....don't risk it!! -
Are you sure they're FLV videos, and not Shockwave Flash/Director videos combined with a player?
But, yeah, I'd be extremely wary of them, too. Better not to take the risk. There's no 'self-playing FLV videos' out there, that I'm aware of. (Yes, I know someone could probably easily create some by combining an FLV with one of the simple players, like Flash does, but there's nothing official, and I'd be worried about .EXE files coming from an 'unknown' source.)If cameras add ten pounds, why would people want to eat them?
Quick Advice on how I should go about getting my vhs onto my computer
By Teebo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2012, 01:07 -
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 13:39 -
Quick FLV Splitter?
By sp0oon in forum Video ConversionReplies: 4Last Post: 7th Mar 2010, 09:27 -
any advice on quick and dirty vhs conversion to dvd?
By cheap in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2009, 20:29 -
Maybe some quick advice
By jfharper in forum ProgrammingReplies: 0Last Post: 9th Nov 2007, 23:49
