    Jul 2009
    I would like to play certain "clips" of a DVD. This means from a certain starting time to a specific end time. Ideally I could program the DVD player so that it will jump from one clip to the other. Even better would it be if it would play more than one DVD and it could still jump between the clips but i dont thikn thats possible (it could also be a software solution on PC but preferable a standalone DVD).
    So for example:
    Clip one starts at 11min and ends at 13
    then it jumps to clip two which starts at 31min and ends at 45 min
    and so forth
    Till this point i used a Video editing software to "clip" out those clips and than just play them of my hardrive but due to rules and contracts I am not allowed to do that anymore. I appreciate any suggestions!
    Get the rules and contracts amended.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I haven't seen a standalone player that is programmable in that fashion.
    Google is your Friend
    Jul 2009
    Do you know if there is a software option?
