Hello.
Im working in A E 6 and I cant seem to fit any more info on the time line ,is ther a limit? its nearley full page and I only 3 more items to add.
Ive tried shift/+ but no results
Any help would be appreaciated
Pete
Results 1 to 9 of 9
Does it have a composition setting function? When I start to run out timeline in AE CS3, I go to Composition->Composition settings, set the duration to a longer time, and proceed from there.
There are no problems - only chances to excel.
-- Unknown -
Hi.
Ill give it a try,acually it would be enough if it would just scroll up.it did once but alas not again,
pete -
Sorry I misunedrstood your post. If my first sugestion doesn't do it for you, you may also Pre-compose the existing video, then that would give you more room for the remaining items.
-- Unknown -
Hi,
My fault,Do you mean by pre-compose,to start again,not sure what you mean,must be the weather,
Its the COMP window thats too small and wont allow further aditions to the time line.
pete -
I'm at work now, so I can't be sure, but I think it's in the Layers menu, near the bottom where the Auto Trace function is. You select with layers you're finished with, select Pre-Compose, they will be merged into one layer.
-- Unknown -
Thanks for your patience and sorry to disturbe you at work,sounds lke that will work out Ok
im a bit new to all this at this level so your understanding is appreciated,really.
pete -
I'm not understanding your problem so its hard to help. I'm not sure if you mean number of layers in a comp, or length of comp ?
A general word of warning though, always be careful with precomposing, moving attributes / unassosciating attributes can lead to some un-desired effects later when you try to work with things. Generally if you want something to be precomposed you want to either precompose it first, before you do anything. Or once it is entirely done with and no more work needed (in relation to other objects you arent precomping with it). Generally not part way through working with objects. Hope that makes sense. -
Hello fitch.
Its the number of layers in the comp,It seems Ive reached a limit as I cant scroll up to add more content.
pete
DVD slideshow GUI - Make effect start at same time as transition?
By trueski in forum ProgrammingReplies: 7Last Post: 6th Feb 2011, 20:05 -
How can I get a print out of all the clips on my time line.
By ozstar100 in forum EditingReplies: 0Last Post: 23rd May 2009, 18:50 -
problem with time line video
By melo7 in forum Video ConversionReplies: 6Last Post: 10th May 2009, 13:46 -
Vob2MPG Pro Time line issues
By Bengleck in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 9th Apr 2009, 12:38 -
multicamera - time syncronizing for split screen effect....
By foler in forum EditingReplies: 3Last Post: 6th Nov 2008, 16:04
