Hi,
I am sure that this gets asked quite a bit so I will try and provide as much information. I am trying to convert a .mov file to iphone H264 format. It seems to convert the file ok but when its finished there are two files created. A .mp4 and a .wav file. For a start off I thought there should only be 1 file created! Why is this so? Also the .wav file is 0 Bytes in size!
I have pressed the info button and I copied it below. Hope someone can help?
Encoding started on Sun Jul 26 10:47:42 BST 2009
x264 [info]: using SAR=1000/1001
x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2
mp4 [info]: initial delay 0 (scale 30000)
movtoy4m
Copyright 2002-2006 Johan Lindström
All rights reserved..
Encoding audio..
x264 [info]: slice I:8 Avg QP:15.75 size: 25931 PSNR Mean Y:51.99 U:54.68 V:55.69 Avg:52.81 Global:52.43
x264 [info]: slice P:1915 Avg QP:15.02 size: 102 PSNR Mean Y:52.37 U:54.90 V:55.85 Avg:53.15 Global:53.11
x264 [info]: mb I I16..4: 69.2% 0.0% 30.8%
x264 [info]: mb P I16..4: 0.0% 0.0% 0.0% P16..4: 2.7% 0.0% 0.0% 0.0% 0.0% skip:97.2%
x264 [info]: final ratefactor: -4.57
x264 [info]: PSNR Mean Y:52.364 U:54.901 V:55.848 Avg:53.150 Global:53.112 kb/s:50.15
encoded 1923 frames, 45.74 fps, 50.25 kb/s
error: could not convert audio track!
Computing levels...
normalize: WAV header not found
normalize: error reading /Users/xxx/Desktop/xx.mov.ff.wav
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
configuration: --enable-memalign-hack --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 04:58:19, gcc: 4.0.1 (Apple Computer, Inc. build 5250)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/xxxl/Desktop/xx.mov.ff.video.mp4':
Duration: 00:01:04.1, start: 0.000000, bitrate: 51 kb/s
Stream #0.0(und), 29.97 fps(r): Video: h264, yuv420p, 640x352
/Users/xxx/Desktop/xx.mov.ff.wav: Unknown format
	ffmpegX does the conversion in steps: first the video, then the audio, then combining the two. If the audio conversion would fail, then you would end up with an output video file and a non-functional/broken audio file.Originally Posted by paul_b
 Please tell us a bit more about the audio format in the source file. Try MediaInfo Mac if other information tools fail.
	Thanks case for the info. I have just downloaded mediaInfo and the have listed the output below. Hope you can help.Originally Posted by Case
 *** MediaInfo Mac // Plain text file report
 2009-07-26 18:25:23 +0100
 Information for File: 00_02_exfiles.mov
 General / Container Stream # 1
 Total Video Streams for this File -> 1
 Total Audio Streams for this File -> 1
 Video Codecs Used -> AVC
 Audio Codecs Used -> AAC LC
 File Format -> MPEG-4
 Play Time -> 1mn 4s
 Total File Size -> 1.03 MiB
 Total Stream BitRate -> 135 Kbps
 Encoding Library -> Apple QuickTime
 Video Stream # 1
 Codec (Human Name) -> AVC
 Codec (FourCC) -> avc1
 Codec Profile -> Main@L3.1
 Frame Width -> 880 pixels
 Frame Height -> 660 pixels
 Frame Rate -> 8.632 fps
 Total Frames -> 553
 Display Aspect Ratio -> 4/3
 Scan Type -> Progressive
 Colorimetry -> 4:2:0
 Codec Settings (Summary) -> 2 Ref Frames
 QF (like Gordian Knot) -> 0.012
 Codec Settings (CABAC) -> No
 Video Stream Length -> 1mn 4s 66ms
 Video Stream BitRate -> 59.3 Kbps
 Video Stream BitRate Mode -> VBR
 Bit Depth -> 24 bits
 Video Stream Size -> 464 KiB (44%)
 Date of Original Encoding -> UTC 2008-10-07 17:12:06
 Audio Stream # 1
 Codec -> AAC
 Codec (FourCC) -> 40
 Audio Stream Length -> 1mn 4s 64ms
 Audio Stream BitRate -> 72.0 Kbps
 Audio Stream BitRate (Nominal) -> 64.0 Kbps
 Audio Stream BitRate Mode -> CBR
 Number of Audio Channels -> 1
 Audio Channel's Positions -> C
 Sampling Rate -> 48.0 KHz
 Bit Depth -> 16 bits
 Audio Stream Size -> 563 KiB (53%)
	I've tried to create a file with the same specifications (.H264 video Main L3.1 880x660 @ 8.632 fps, AAC audio 48kHz, in a .MOV container) and convert it with the iPhone preset in ffmpegX. It converted fine, with audio. So, I'm stumped as to why it won't work on your side.
 Is it possible for you to upload your source file somewhere so I can have a try at your file?
  Converting MOV videos to DVD from iPhone 4SBy jpifer_nc in forum Video ConversionReplies: 4Last Post: 11th Dec 2011, 13:23
  Remove frames from an iPhone 4S video (MOV) without re-encoding?By kingmustard123 in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2011, 12:18
  iPhone MOV to H264 AVIBy kr1ge in forum Video ConversionReplies: 2Last Post: 15th Sep 2010, 11:49
  Can't Convert Trimmed IPhone MOV (Fast Motion)By xr280xr in forum Newbie / General discussionsReplies: 4Last Post: 1st Jul 2010, 01:50
  Tool for croping a .mov video for use as vWallpaper on the iPhone?By mr_jbloggs in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 13:05
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
