Hi All,
I am looking at buying a new camera, Panasonic Luminx TZ7, will Adobe Premier Elements recognise the HD voider recodered in AVCHD Lite Mode, I don't want to buy the camera only to find out my editing program clashed with the file footage from the camera.
Thanks,
Nick..
Assume not unless you can verify otherwise in a Lumix or Premiere Elements forum with actual users.
AVCHD "Lite" seems to be more of a marketing term than a technical specification and is deceptive and non-descriptive IMO. The AVCHD official site says AVCHD Lite means restricted to 1280x720p. Original AVCHD was 1440x1080i. I assume 1920x1080p might be called AVCHD "heavy"?
Typical 1280x720p AVCHD has a 17Mb/s bit rate and a 15 frame GOP (at 30p) but the standard is loose and often not compatible between manufacturers.
Normally "PAL" equipment use 25 fps and a 12 frame GOP. Many digital cameras seem to be ignoring 25fps. This is important if you want to convert to PAL DVD or PAL Blu-Ray without frame rate conversion losses.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Adobe Premier Elements 4 templates - can I import a single one
By jlbvt in forum Authoring (DVD)Replies: 0Last Post: 7th Mar 2011, 10:53 -
menu title in adobe premier elements 2.0
By qualityphoto in forum EditingReplies: 0Last Post: 30th May 2009, 14:35 -
Problems with Adobe Premier Elements
By jeffprice74 in forum EditingReplies: 4Last Post: 21st Jun 2008, 11:24 -
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 23:01 -
Adobe Premier Elements 4 audio issue
By Dark Alpha in forum EditingReplies: 0Last Post: 26th Jan 2008, 17:02
