Hi folks,
Q: I was wondering if there is a Faster way of forwarding an AVI while watching it on a TV via my Philips DVD Player?
Scanning thru the entire of 2 hours of an AVI just to get to the last 10 minutes of the AVI so you can watch it where you stopped it ... is getting to be a pain in the neck!
Is there an easy way of scrolling thru an AVI ... same as going thru a regular DVD?
Thanks,
G!![]()
No, not unless you segment the AVI (split it into several smaller videos), or author a DVD-Video disc with chapters. Chapters (or skipping around in a similar manner) aren't supported in most DivX/Xvid players for AVI/.divx playback (and not in the original AVI format, anyway).
Though, if your Phillips player cues up to 32X, like my 5990 does, running through a two-hour video might not be as bad.
If cameras add ten pounds, why would people want to eat them? -
Hi Ai,
Yeah man that is where I am at 32X ... but still it is slow ... like I should make a run to the frig and back and still not cued fast enough. Making a dvd to me it is a waste of time and DVD.
THANKS!
G!
In my Philips DVD recorder, I can pull up the info, and type in a timecode with my remote, press ENTER, and it jumps to that spot. Look for this, or read your manual.
Huh. Learn something new every day.
I've experimented a bit (manuals? Who needs them? :P), and found that one method that works on my 5990 is to hit the Title button on the remote twice so that "Go To -:--:--" is displayed, and you can enter a time to jump to (it'll automatically do it when you press the last number).
Sorry - I didn't think the Go To time jump worked with AVIs, and I typically don't watch any video files longer than half an hour or so on the player, so I usually just cue to the spot I want to play.
Brilliant, lordsmurf! I never even thought to try this. Thanks!
'Tis good to RTFM once in a while...Originally Posted by tomlee59
My 5982 does the 32X thing, but it seems to actually be far slower than that after a short while. I guess it must be my USB stick.Originally Posted by Ai Haibara
VHS fast forward effect
By ewing in forum EditingReplies: 4Last Post: 7th Apr 2010, 05:32 -
Video stucked when fast-forward
By dk2000 in forum Capturing and VCRReplies: 2Last Post: 23rd Jan 2008, 09:08 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 21:48 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 19:49 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
