Hello people
At the time I'm trying to convert my captured avi to divx but for some reason don't work.
I've followed the guide on this site (vdub guide), but when I press save it says that the divx is hacked. Now I've tryed to download the 3.11 that is on this site and I have tryed 4.12, but it still sayed that it is hacked, and when I say that it sould just go on that little pop-up comes up but nothing happens, I let it run for 1 hour and 40min. but still nothing.
Is there a special divx codec I shall youse?
Can I youse the 4.12 codec, if do I half to install both 4.12 and 3.11 cause with only 4.12 vdub can't find a divx compression to the sound?
Hi there.
1 - ignore the warning about it being a hacked codec, all divx are hacked codecs and the warning is, i think, a legal 'getout' type thing from the program's author.
2 - it can take ages to convert avi to divx (depends on cpu, filesize,resolution etc...). As long as the pop up window shows 'activity' then just leave your computer on and go to bed.
The pop up should show you an estimated finish time (it can take a little while to settle down so don't rely on the initial estimates it gives). But just work it out for yourself. If vdiub is processing 5 frames per second of a video which is 25fps format, its going to take 5 times longer than the source to encode!
I've routinely spent 24hours doing encodes - patience is a virtue!
convert .divx to .avi
By ad_jack in forum Newbie / General discussionsReplies: 15Last Post: 10th Feb 2013, 09:27 -
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 06:19 -
Convert MKV to AVI or DIVX
By ranosb in forum Video ConversionReplies: 4Last Post: 3rd May 2009, 22:59 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26 -
Convert AVI to Divx
By shankie in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jul 2007, 02:52
