Results 1 to 11 of 11
    Jul 2009
    Canada
    I have a number of .dts files on my hard drive that I'd like to burn to a Digital Audio DVD in a format that my car stereo will recognize, and be able to play in 5.1 surround.
    Any suggestions?
  2. I am not aware of any car stereos that can play DVD Audio, if you have a DVD player there's a 50/50 chance of it playing DTS on a DVD Video.
    I would convert the files to MP3, AAC or WMA and put them on a CD.
    BTW: do you have a 5.1ch surround system in your car?
  3. Banned
    Freedonia
    Such players are rare, but they do exist. One of my friends has either and Acura or a Lexus. I don't remember which, but I think it's a Lexus. It came standard with a DVD player and the player says it supports DVD Audio.
  4. Originally Posted by chrisf71
    ...format that my car stereo will recognize...
    We need significantly more information on your car stereo.
    -drjtech
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
    Jul 2009
    Canada
    Hi, there.
    I got an Acura TL Tech. It's got ten speakers in 5.1 surround. I'm not sure who makes them for Acura, unfortunately. It definitely supports DVD Audio; they gave me a sample Audio DVD with the car, and it sounds AMAZING.
  6. You could use DVDLab Pro to make a DVD Video:
    https://forum.videohelp.com/topic287574.html
    DVD Audio software such as DiscWelder requires PCM files so you will have to convert.
    You might want to use MediaInfo to check the properties of the DTS files first.
  7. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    That manual is for older DLP versions. Modern DLP has an 'audio-only title' option and ability to use individual still mpeg picture for each chapter. The process is the same as for making video DVDs.
  8. DECEASED
    Jun 2009
    Heaven
    You can convert your DTSs to uncompressed WAVs, and then
    author an actual DVD-A disc with dvda-author and a patched version of mkisofs:
    http://dvd-audio.sourceforge.net/
    HTH.
    P.S.: Some pages of that site are outdated ---
    --- the latest versions of dvda-author do support multichannel audio.
    Jul 2009
    Canada
    Thanks for all the input.
    Will I lose any sound quality by converting the .dts files to another format before burning the audio dvd?
  10. Video Restorer lordsmurf's Avatar
    uncompressed WAVs
    No. Not if it's an uncompressed format.
  11. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I don't use DLP, but this sounds like it's not really "DVD audio" but a normal video DVD (a slideshow) -- it will consist of VOB files in the VIDEO_TS folder.
    GfD has a similar option, called "audio titlesets".
    See http://dvd-audio.sourceforge.net/ as mentioned earlier for details of true "DVD audio" format.
    This will contain files in the AUDIO_TS folder.
    This may be important if the player can play DVD audio, but not video.
