Source .Ts file is 25fps(Pal). Using Tsmuxer I demux video & audio, slowdown the video to 23.976fps.
Then Eac3to converting the source ac-3(stereo) to a stereo wav -slowdown, but it detects that the source audio has a -32ms delay on it, and auto removes this. "Track not clean"
Putting the video/audio back together, and making them back in sync, I use Tsmuxer to make a AVCHD, combining video/audio with -32ms on the audio.
It plays in sync, but as usual, sometimes the bluray player will hiccup on almost all avchd playback (stop and advance the movie the amount of the delay) which continues w/o any problems.
But when this video did just that, it went back out of sync! Ouch!
Any advise on how to fix this and why the original video had a delay on it?
If deleting the delay fixes the audio, how do you make the video sync with it?
Source Audio:
Thanks experts!Code:Format : AC-3 Format/Info : Audio Coding 3 Duration : 4mn 29s Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Video delay : -36ms Stream size : 12.4 MiB (3%) Language : English
EDIT: Apparently the Source was corrupt at a certain spot, it repeated at the same spot(Went out of sync) on every Avchd creation. So I tend to believe these hiccups are not the bluray player, but errors generated when using Tsmuxer for Avchd/Tsmuxing/M2ts...
The SOURCE, probably was created with Tsmuxer/Tsmuxing.
Also a better sync I used BdPowerAmp and added silence of 32ms at 0:0:0, which also synced the video...
Any comments?
By the way, what do you do with 50fps video for playback on a Ntsc system?
Audio out of sync, how to determine delay needed.
By mattstan in forum Authoring (DVD)Replies: 9Last Post: 23rd Dec 2019, 03:26 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Video scattering , audio sync variable delay in MKV files
By prabhakarlad in forum Software PlayingReplies: 13Last Post: 22nd Apr 2011, 15:55 -
URGENT: Any Blu-Ray players with adjustable audio delay / lip sync feature?
By psychotronicfilms in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Feb 2011, 20:45 -
Audio Delay and other potential A/V sync Issues?
By rkr1958 in forum AudioReplies: 1Last Post: 2nd Dec 2007, 15:33
