I intend to add a new language track (L2) to an existing DVD. But the added audio file is damaged in certain parts, so I will replace these segments with the original language (L1). Whenever L1 is on, I want subtitles corresponding L2 to be automatically shown then disappear when L2 is back again.
Is it possible to do so? How?
Thanks is advance.
Yes, it's not only possible but fairly easy, if you know what you're doing.
There are no other subs except for those to be used when the L1 portion of the audio track is playing? If so, create a subtitle file with just that part and have it play by default with the L2 audio (which contains a short section (or several short sections) of the L1 track).
Using PGCEdit to create a SetSTN command to be added as a pre-command just before the movie starts can easily set the audio and subtitle track to play. But there may be more here than meets the eye, so links to guides will wait a bit.
Also, you seem confident that you can fix the audio the way you want. So I'm assuming you also know how to create a subtitle file suitable for authoring for DVD. But you haven't told us what you're using to reauthor this thing or how much you know, if anything, about creating subtitle files.
How can I force my Video Converter to read Unicode UTF-8 subtitles?
By MoneyHoney in forum SubtitleReplies: 7Last Post: 27th Apr 2012, 20:13 -
How to Get Subtitles for Parts of Movie Not in English?
By Qzz8zz in forum Newbie / General discussionsReplies: 4Last Post: 28th Jun 2011, 15:31 -
how to get subtitles for only the non english parts
By beargore in forum SubtitleReplies: 3Last Post: 10th Dec 2009, 09:14 -
Looking for subtitles for just foreign language parts of movies
By Wingit in forum SubtitleReplies: 1Last Post: 16th Jan 2008, 03:02 -
Cyrillic subtitles not shown corectly on DVD player
By uher in forum SubtitleReplies: 1Last Post: 10th Dec 2007, 15:05
