I have seen British AC Ace's with Ford 260's, 289's, 427's and 429's in them. One might have even been a side-oiler.
Results 61 to 71 of 71
Well the main thing to see if your CPU is bad is what gets displayed on the screen ?? If its active for five seconds(?) you should be seeing something about post and ram testing etc etc. If nothing gets displayed on the screen then perhaps it is the CPU. 5 secs sounds like enough time to warm up to critical temp and then shut down. This may or may not be erroneous. If the CPu is truly FUBAR then the PC will shut down instantly/fail to power on.
I would check CPU heatsink, Fan and Fan connectors to MB.. whether 3 or 4 pin or RPM controlled.??Corned beef is now made to a higher standard than at any time in history.
If memory serves...Originally Posted by DarrellS
Those Porsche-engined VWs were "polizei" versions in Germany, and it was awhile before it became general knowledge they had them. Imagine the surprise of motorists seeing one of those on the Autobahn at full speed. :PPull! Bang! Darn! -
Exactly, which is why it makes sense to buy a base speed cpu from a manufacturers premier line early in production before the build up a stock of low yield wafers (that is if you are into over clocking)Originally Posted by jagabo
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Yep!!
Bad CPU!!!
I received the replacement earlier this afternoon, fired right up, installed XP Pro x64 & all is good.
Just my luck i would get the 1 in a million new bad CPU
By the time i posted i was already to the point of assuming it was probably the CPU but figured i may as well try because ya never know.
And i did get some other good ideas of what it could be that never occurred to me.
Thanks everyone for all the brainstorming & help. -
After 10 years, the law of averages caught up to you.Originally Posted by Noahtuck
Glad you got it fixed. -
Thanks!
Yep... hopefully it will be another 10+ years
What a PITA
Good to hear you got a replacement cpu and all is good!
this is good to hear..I have a desktop that is behaving the same way..one of the clips broke off on the heatsink so I used a plastic zip tie to hold the spring arm down, but apparently it isn't doing the job right b/c it's powering down randomly after a few seconds of use
. The heatsink mount is part of the motherboard though so It looks like I'm stuck! oh well it was an old desktop anyways...
Buy an aftermarket heatsink and fan that screws to an adapter on the back of the motherboard. Hopefully you haven't fried anything already.
Gotta replace the bracket with a gigbyte one cause a lot of them are custom built for the mb,if the heatsink was good enough then you dont have to replace that if it didnt get broken.Originally Posted by DarrellSI think,therefore i am a hamster.
Canon Hi8 A1 won't stay on
By Sew Sporty in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Jan 2011, 21:51 -
PC Monitor Won't Stay On
By The Monkees in forum ComputerReplies: 4Last Post: 11th Mar 2008, 00:15 -
Computer keeps shutting down, won't stay on.
By Super Warrior in forum ComputerReplies: 6Last Post: 9th Aug 2007, 16:34 -
OGMDemuxer won't stay open...
By deepdiev in forum Video ConversionReplies: 3Last Post: 13th Jul 2007, 03:07 -
XP won't stay with the appearance I pick
By The Fred in forum ComputerReplies: 21Last Post: 13th May 2007, 14:35
