can anyone help when i install the latest versions of bdrebuilder it comes up expired install a new version any ideas
Ask Jdobbs - The creator of DVDRebuilder, and likely the best bargain of the time. I'm not going to help you on this - there's plenty of support, as always.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Hi everybody, I'm new to this forum. So bear with me if I am asking a stupid question.
I have the same issue as described above although I downloaded the latest version from the author's page on doom9.org.
I wanted to ask this question on their forum but I have to wait 5 days after registration (which I did today) to post anything.
I just upgraded to a Q9550 today and feel this is all wasted if I can't get the program to run.
Is someone able to help me on this ?
Any help would be more than greatly appreciated.
Keep up the good work on this forum.
Cheerz
-- Viologolem -
It is quite a simple task
Just set your PC clock and date to August 4th, 2009 (today) and unless you're living in another universe (which doesn't keep time as ours) it should work
An important note: Whenever you decide to do hardware update or bios reset - ALWAYS set your proper date/time settings. Skipping it may cause you much more trouble.
DeanLaugh and the world will laugh with you. Cry and you will be alone -
Geez you're right.
When I reinstalled my CPU I accidentally encoded 04/04/2009 instead of 04/08/2009.
What a stupid mistake.
I am SO ashamed
It's working !
Thanks for your quick reply
--- Viologolem
Convert expired WMA to MP3
By pchan in forum AudioReplies: 4Last Post: 20th Jul 2011, 09:44 -
BD Rebuilder show that the beta is the expired date when the first run.
By wisitch in forum Authoring (Blu-ray)Replies: 2Last Post: 12th May 2011, 08:29 -
DVD-Lab Pro expired
By jonghyunchung in forum Authoring (DVD)Replies: 7Last Post: 25th Mar 2010, 11:43 -
DVD2oneX2 - Expiration expired (Is there....)
By JonnyPhoenyx in forum MacReplies: 5Last Post: 8th Mar 2009, 13:17 -
TMPGEnc has expired what do I do?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 13:55
