Could someone please give me some advice? I'm wanting to know what would be the best video ports to use for my DVD player -> projector setup. There's so many different ports it's mind boggling. My setup is:
DVD Player
Sumvision HDMI Upscaling Pal DVD Player
Ports:
Scart Out
HDMI
'A/V OUTPUT' ports: Y, Cb/Pb, Cr/Pr, Audio Left, Audio Right, Coaxial
'VIDEO OUT' ports: Component Video, S-Video
Optical port
'AUDIO OUTPUT' ports: SL, CEN, SR, SUB
Projector
Optoma DLP EP716R Projector
Basic Specs:
Native Resolution: SVGA 800x600
Compressed Resolution: XGA 1024x768
Brightness: 2200 lumens
Contrast Ratio: 2000:1
Ports:
2 x VGA Ports (One says 'SCART - ' next to it)
Audio
S-Video
Component Video
VGA-Out
RS-232
I'm basically just wanting to know which ports I should use at both ends to get the best resolution/colour/quality for playing movies. And do I need any converters or anything, and if so are they worth the cost?
Any help would be greatly, greatly appreciated.
Thanks everyone. Lee
Best match is analog component (Y,Pb,Pr).
Check to see if the projector accepts 720x576p (progressive). Otherwise set the DVD player to 720x576i and let the projector deinterlace.
Audio is best sent as digital (optical or coax) to a surround capable receiver.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks for your reply. I'll try and find out if the projector accepts progressive or interlaced. If I use component, will that go to VGA I assume? Will I need a converted for that or a special cable?
Thanks for your help. -
Component inputs look like this.
I looked this projector up. It seems analog component inputs require some sort of option that can't be found.
http://www.aboutprojectors.com/pdf/optoma-ep716r-specs.pdf
This projector is intended for conference room business presentations from a laptop (VGA) more than movies from a DVD player. Your options are limited to composite or S-Video unless your dealer can find an analog component option.Recommends: Kiva.org - Loans that change lives.
This projector should have come with a VGA-Scart adaptor, which will plug into the VGA port that also has "scart" labelled.
This might be the easiest option to connect your DVD player.
Need solution on my New Rear Projection TV
By tony1960 in forum DVB / IPTVReplies: 14Last Post: 15th Jul 2008, 19:36 -
Rear Projection TV Help
By Alienverse in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2008, 00:34 -
Projection TV
By joytimeday in forum DVB / IPTVReplies: 3Last Post: 4th Jan 2008, 00:57 -
How to know which ports are in use on a PC?
By deanbrown3d in forum ComputerReplies: 2Last Post: 21st Sep 2007, 05:28 -
anybody know how to refocus a projection tv?
By tonydahose in forum DVB / IPTVReplies: 2Last Post: 6th May 2007, 09:52
