  1. Is there a good free program that allows splitting ,resizing and merging of partition hard drives.
    May 2009
    Check out the web site:
    http://partedmagic.com/
    They have an ISO file that will set up a bootable cd with partitioning tools etc.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    I second that. I used it to shrink and extend partitions and to make room for Windows7.
    I haven't yet risked using it on an OS partition. I did use it to create blank disk space then used Vista Disk Manage to enlarge the Vista partition.
    In the past I had to move drives to an XP machine to use Partition Magic 8.
    http://www.kiva.org/about
