I've tried installing the 1.3 Beta version on two different computers and the same error appears when I try to open the App. Here it is: -- C:\Program Files\Audacity 1.3 Beta (Unicode) \audacity.exe
This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.
This message is on both computers
Anyone else have this problem?
GT
"You have not because you ask not"
James 4:3 -
I have never had an issue installing Audacity before, but give this a try a see if it works for you.
Go to :
http://audacity.sourceforge.net/download/beta_windows
Scroll down the page a bit to the Optional Downloads section and you will see this sentence:
"Windows 2000/XP/Vista: Audacity 1.3.8 zip file (7.5 MB) - If you want a download without help files, or cannot run the installer because of restricted permissions, download and unzip this or the file below instead"
Download the file referenced there. Once unzipped , you (should) have a working version of Audacity. This what I have been using for the last several versions of the program, and have not had any problems. Don't forget to get the Lame MP3 encoder if you want to use MP3 files.
Edit: Also once you have everything unzipped and configured etc, all you need to do is copy that folder to any other PC you may want to run it on. -
The latest Audacity 1.3.8 beta is very buggy. It will work on my Laptop with XP, but won't work on my desktop with XP x64 with either the zip or installer used. I get a Runtime Error in XP x64. All previous versions work great and I'm currently running version 1.3.6 without any issues.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
The only problem I had with installation was an inability to set the FFmpeg library location. This was installing over version 1.37 on an XP SP3 machine. Uninstalling completely and reinstalling clean solved it, I guess this is always a good idea with beta software.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
That would probably be a good idea, especially if the OP is having problems w. a normal install. They are here:Originally Posted by racer-x
http://sourceforge.net/projects/audacity/files/
GT Music, if your computer profile is showing what update levels you are currently running at, you may want to update XP and your systems drivers to their most current versions, and see if that helps.
Audacity Mac 1.3 Beta - solved my problem but how?
By Rhymester in forum AudioReplies: 5Last Post: 27th Oct 2011, 08:43 -
Installation error
By johnsonk in forum ffmpegX general discussionReplies: 2Last Post: 14th Aug 2009, 11:05 -
Installation Error In Leopard
By Lefty! in forum ffmpegX general discussionReplies: 3Last Post: 6th Dec 2008, 04:14 -
vegas 6.0 installation error
By scd250 in forum Software PlayingReplies: 3Last Post: 27th Feb 2008, 21:09 -
Installation error -
By ruggerjvd in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2007, 09:06
