Can someone please tell me, how I can convert a specified DVD clip into a uncompressed AVI file? All I want to do is to select the scene (clip) that I need (for example from minute 16:57 to minute 20:13) and then rip it into the AVI file. I found thousands of tools, but 50 percent of them aren't working or to difficult to look through and understand.
Is there any free (or if not payable) tool that handles my problem?
Thanks for all your hints. I am new in the video 'business'.
If it's a commercial DVD you'll need to rip to the hard drive first with DVD Decrypter, or DVD Fab. Then open a VOB file with VirtualDubMod, mark the section you want to save, and save as AVI.
Or use dvd shrink in the reauthoring mode to select the part you want. Save. Open then vob in virtualdubmod, avidemux or xvid4psp and save as uncompressed avi or dv-avi.
Is there any step-by-step tutorial you could recommend? I don't know what to do with all this programs. Neither do I know what codecs I should have installed on my system...Originally Posted by jagabo
Best/Fastest way to easily convert a dvd (.VOB) to .avi
By xxnonamexx in forum DVD RippingReplies: 21Last Post: 4th Sep 2010, 13:17 -
Best/Fastest .avi to dvd convertor/burner?
By xxnonamexx in forum Video ConversionReplies: 2Last Post: 24th May 2010, 20:53 -
What is the fastest program for DVD to avi conversion?
By danozard in forum DVD RippingReplies: 5Last Post: 13th Sep 2009, 03:54 -
Fastest Avi to DVD Converters
By gameroftheuk in forum Authoring (DVD)Replies: 13Last Post: 5th Sep 2007, 13:32 -
Fastest AVI to DVD program
By mjaeson in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 06:09
