    Aug 2002
    Hi All
    i have downloaded a film and the optional 5.1 sound, this is what is says in the nfo file...
    Encoder's note :
    If you will download the optional AC-3(5.1) audio to replace the default MP3 audio for this release,
    You will need VirtualDubMod to do the muxing. It only takes a minute or 2 to create a new AVI file
    w/ 6 surround channel. Screen shot guides are included inside the folder...THANKS!
    i have followed the instructions, found here..
    But when i try and do it, i end up with a film with all the audio out of sync and the sound stutters a great deal, anyone have any ideas,
    here are the video details, if it helps.
    Video Info :
    Format : XVID (2-pass)
    Bit rate : 827 Kbps
    Width : 672 pixels
    Height : 280 pixels
    Display aspect ratio : 16/9 (2.40:1)
    Frame rate : 23.976 fps
    Bits/(Pixel*Frame) : 0.183
    Stream size : 698 MiB (89%)
    Audio Info :
    Format : MP3
    Bit rate mode : Constant
    Bit rate : 96.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 81.0 MiB (10%)
    Language : ENGLISH
    Optional Audio : http://hotfile.com/dl/3264630_...24kbps.ac3.html
    i have the latest version klite installed as well.
    Thanks Pete
    Try also avimuxgui.
    Aug 2002
    thanks for the reply. I have got that program but didnt know you could use that program to add a track, i have just used it to correct lip sync, is there a guide available to add the soundtrack or can you explain how to do it?
    Thanks pete
    Aug 2002
    I Think i have found a guide.
    https://forum.videohelp.com/topic266194.html
    Aug 2002
    Just to let you know that i followed the guide shown in the above link and it worked like a dream, thanks for the advice
    Pete
