    Jul 2009
    Add a Photo to My Computer Properties
    To do this:
    1. Open Notepad.
    2. Type the following:
    [General]Manufacturer="your_name
    Model=HP d530 SFF(DC578AV)
    [Support Information]
    Line1= Your Ph No
    Line2= Your Address.....
    3. Save as "oeminfo.ini" in the System32 folder.(Without Quote)
    4. Create a bmp file(Your Photo) and save it the System32 folder as "oemlogo.bmp"(Without Quote).
    5. Now Check your My Computer Properties.
    Jul 2009
    Hide ur folder with command prompt
    1.start "run"
    2.type "cmd" hit enter
    3.after cd.. type ur path with "attrib" command
    like
    to hide
    c:\ attrib +s +h d:\ fun hit enter
    to show
    c:\ attrib -s -h d:\ fun hit enter
    you done!!!
    Jul 2009
    How To Customise Your start Button :-
    First you need a tool called "Resource Hacker". This free program allows you to change resources in any .exe file such as "Explorer.exe", which includes the [Start] button's Label. You can visit Download.com and search there for "Resource Hacker".
    After you download it, follow the guide here:
    Step 1:
    A - Run "Resource Hacker" and open the file "%windir%\Explorer.exe".
    B - You see a Tree of all Resources in this file, expand the "String Table"
    C - Find the "start" (look for the place 37->1033 on the "String Table") and replace it with your own text. then press the [Compile Script] button.
    D - Save "Explorer.exe" as "MyStart.exe" DONT save it as Explorer.exe, do "save as.." and give it a new name.
    E - Quit "Resource Hacker".
    Step 2:
    A - Click on the [Start] button and choose the "Run..." item from the start menu. (Or use the shortcut key WinKey+R)
    B - Type "RegEdit" in the Run "Dialog Box". And then press the [Ok] buton to run the "Registry Editor" program.
    C - Go to: "HKEY_LOCAL_MACHINE\SOFTWARE\Mcft\WindowsNT\Curren tVersion\Winlogon" and find the "Shell" property.
    D - Replace value of the "Shell" property to "MyStart.exe".
    E - Quit "Registry Editor".
    F - Restart your system.
    Note about Registry Editor:
    if you did not find the key "HKEY_LOCAL_MACHINE\SOFTWARE\Mcft\WindowsNT\Curren tVersion\Winlogon", you can search the Registry for the "Explorer.exe", to do this use the Edit Menu | Find Next (Ctrl+F).
    Jul 2009
    Display a message on your computer before Windows XP loads. Very useful when the owner of thecomputer wants to define some rules for using the system that an user must read before.
    1. Go to Start->Run.
    2. On the Run window type regedit and press Enter.
    2.Navigate to the key HKEY_LOCAL_MACHINE\SOFTWARE\Mcft\Windows NT\CurrentVersion\Winlogon.
    3.Modify the key legalnoticecaption and write the name of the window you want to appear.
    4.Modify the key legalnoticetext with what you want the window to say.
    5.Restart your computer.
    Now when your computer starts a window with the name and text defined by you will appear on the screen before Windows XP is loaded.
