this has been bashing my brain in, so i have a video (ninja scroll remastered) in AVI format. it plays great on my mac through divX and VLC, i am trying to get it stored on my playstation 3. when i try to play the file on the ps3 the video play's fine but the audio doesnt work. first i tried the divX converter. which worked to produce sound, but the sync of the sound is way ahead, i figured i would try some other stuff people have been doing around the web. i have 2 computers a 2009 mac mini and 2008 late model macbookpro with bootcamp and a copy of windows vista 64 bit. so ive tried using ps3 video 9, SUPER, and DivX converter. they all seem to get sound but it does the same out of sync thing with all of them. so i gave in and registered thinking someone here may know how to fix this. i have a cool prog called media info that i thought may help me help you guys help me. :P
here's the info on the file.
*** MediaInfo Mac // Plain text file report
2009-07-22 16:16:30 -0500
Information for File: Ninja Scroll (Remastered).avi
General / Container Stream # 1
Total Video Streams for this File -> 1
Total Audio Streams for this File -> 2
Video Codecs Used -> XviD
Audio Codecs Used -> MPEG-1/2 L3 / MPEG-1 Audio layer 3
File Format -> AVI
Play Time -> 1h 31mn
Total File Size -> 899 MiB
Total Stream BitRate -> 1376 Kbps
Encoded with -> VirtualDubMod 1.5.4.1 (build 2178/release)
Encoding Library -> VirtualDubMod build 2178/release
Video Stream # 1
Codec -> XVID
Codec (Human Name) -> XviD project
Codec (Container Code) -> XVID
Codec Profile -> Streaming Video Profile/Level 1
Frame Width -> 800 pixels
Frame Height -> 608 pixels
Frame Rate -> 25.000 fps
Total Frames -> 136956
Display Aspect Ratio -> 4/3
Interlacement -> Progressive
Codec Settings (Summary) -> BVOP / Custom Matrix
Codec Settings (Packet BitStream) -> No
QF (like Gordian Knot) -> 0.082
Codec Settings (BVOP) -> Yes
Codec Settings (QPel) -> No
Codec Settings (GMC) -> 0
Codec Settings (Matrix) -> Custom
Video Stream Length -> 1h 31mn 18s 240ms
Video Stream BitRate -> 995 Kbps
Bit Depth -> 8 bits
Video Stream Size -> 650 MiB
Video Encoder -> XviD0047
Audio Stream # 1
Codec -> 55
Codec (Human Name) -> MPEG-1 or 2 layer 3
Codec (Container Code) -> 55
Audio Stream Length -> 1h 31mn 14s 760ms
Audio Stream BitRate -> 180 Kbps
Number of Audio Channels -> 2
Sampling Rate -> 48.0 KHz
Audio Stream Delay -> 15s 325ms
Audio Stream Size -> 118 MiB
Audio Stream # 2
Codec -> MPA1L3
Codec Profile -> Joint stereo
Audio Stream Length -> 1h 31mn 16s 488ms
Audio Stream BitRate -> 179 Kbps
Audio Stream BitRate Mode -> VBR
Bit Depth -> 16 bits
Audio Stream Size -> 117 MiB
Audio Encoder -> LAME3.97
Audio Encoder (Settings) -> ABR
any help appreciated.
-kc
EDIT: also used 3gp converter with no luck, however i finally got a working copy with handbrake. witch was actually the fastest, downside the file went from 900mb to 1.5 gb.
but it looks good and sounds good. mod can delete this thread.
It seems that you have two different MP3 audiostreams in your AVI file.
I don't know much about the PS3 device, but the manual:
http://manuals.playstation.net/document/en/ps3/current/video/filetypes.html
says audio should either be LPCM or AAC.
I would try to demux the mp3 audio out of the *.AVI file, recode the audio to *.m4a (aac), and remux the recoded audio into the *.AVI file. (LPCM is probably not an option, because it wil take up 10 times more space than MP3 or AAC).
Converting VFR FLV (H264/AAC) to AVI (other) w/o sync issue
By kwondra34 in forum Video Streaming DownloadingReplies: 43Last Post: 11th Apr 2012, 00:54 -
Video/Sound Issue (h264/avi files)
By o2intake in forum Newbie / General discussionsReplies: 7Last Post: 13th Mar 2012, 09:48 -
Strange issue with playback after converting 720p mkv to downscaled avi
By Phat J in forum Video ConversionReplies: 9Last Post: 24th Mar 2011, 16:23 -
Trouble converting VOB to AVI using Handbrake (audio issue)
By binvisions in forum Video ConversionReplies: 1Last Post: 1st Aug 2009, 03:28 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12
