    Jan 2004
    Iowa, USA
    Thought I'd give this app (v1.7.2) a try -- did a test DVD of 3 AVI clips with a simple menu, and wanted to save the result as an ISO image. When it got to the "Generating DVD" step (after converting the clips OK, I assume), it gave me this "Failed" error message:
    Generating DVD
    Executing command: dvdauthor -o "C:\Program Files\DVDStyler\dvd" -x "C:\Program Files\DVDStyler\dvd\dvdauthor.xml"
    DVDAuthor::dvdauthor, version 0.6.14.
    Build options: gnugetopt iconv freetype
    Send bugs to <http://www.dvdstyler.de/support.html>
    INFO: Locale=English_United States.1252
    INFO: Converting filenames to CP1252
    ERR: Parse error 'syntax error, unexpected $end, expecting COLON_TOK' on token ''
    ERR: Parser failed on code 'g0=1;nothing'.
    Failed
    I think I caused the second error by changing the action command on the main "Menu" button I created from the default selection "jump to title 1" to manually entering "nothing" (I didn't want anything to happen if the "Menu" button was clicked, so... )
    Anyone know what caused the first failure?
  2. I think the 'first failure' is the same as the second. It just says that dvdauthor is missing a final ';' at the statement. Delete the 'nothing', it isn't necessary at all as if you just set g0=1 nothing else will happen.
    Jan 2004
    Iowa, USA
    Thanks, I'll try that.
