Hi, I have just bought a new Mini DV camcorder. It's a Samsung camcorder that is not compatible with iMovie, it doesn't worked and I searched the list of compatible camcorders for iMovie and it was not listed.
So I now have Final Cut Express, and would just want to know how you import you clips on the tape onto the programme.
Thanks a lot and take care
If it is a MiniDV camcorder and has a Firewire port, it should work. You must use a Firewire (IEEE-1394) cable. Set the camcorder to "Play" or "VCR" mode and iMovie or Final Cut Experss should detect it.Originally Posted by yorx22Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
The problem is the camera isn't compatible with iMovie (the camcorder is a SAMSUNG VP-D381), someone told me to try Final Cut Express, so now that i've got it, I just wanted to know how you do it, because I connect de the Firewire cable 6 inch into the computer and 4 inch into the camera, and nothing appears. At the moment I can only get the Capture mode set up, but I still don't know how to import the tape files.
Thanks a lot
Getting Video To Import Into Final Cut Express
By 360Spider in forum MacReplies: 14Last Post: 6th Mar 2012, 09:21 -
Import Panasonic Mini-DV camcorder files to Final Cut Express?
By benalen01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 15th Mar 2010, 02:04 -
Importing VOB files--iMovie, Final Cut Express? New to Mac
By Theresa in forum MacReplies: 14Last Post: 7th Apr 2009, 08:54 -
With a mac how do I convert a Final Cut Express item to mpeg2 dvd?
By dagardenguy in forum ffmpegX general discussionReplies: 2Last Post: 16th Jan 2009, 12:00 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
