Okay, I'm not sure what I'm missing. Yes, I'm new to working with x64 Windows.
I've got the 64-bit version of MPCHC, installed the x64 version of ffdshow (and enabled subtitles there), grabbed the 64-bit version of VSFilter.dll and copied it to the SysWow64 directory (if I remember the directory name correctly... and, don't I have to register the DLL, somehow? I know how to do that with 32-bit DLLs, but not 64-bit DLLs.)
Even installed the VobSub/DirectVobSub package (just to be sure) and Haali Media Splitter (again, just to be sure). Even after all that, however, no (soft) subtitles appear when playing videos in MPCHC. They DO appear if I load the videos into MPC (32-bit, of course), but I'm trying to get it to work in MPCHC.As far as I can tell, I've got all the display options set correctly in MPCHC, and everything. It just... doesn't want to display subtitles, even through ffdshow's own subtitle engine.
No - it's set to VMR7 renderless. (That's one of the settings I meant with "all the display options set correctly in MPCHC," actually. I probably should have said that instead of the vague quote.)
How to get best sound output in MPCHC?
By skorpinok in forum Software PlayingReplies: 11Last Post: 27th May 2011, 15:45 -
MPCHC and *.sup subtitles
By zanmat0 in forum Software PlayingReplies: 1Last Post: 25th May 2011, 05:24 -
file not found in MPCHC
By hamdy in forum Software PlayingReplies: 3Last Post: 5th Nov 2009, 16:40 -
Help With Vista64
By pangpanz in forum ComputerReplies: 9Last Post: 8th Jun 2008, 12:51 -
Vista64 playing wow with low fps
By johns0 in forum ComputerReplies: 13Last Post: 28th May 2007, 20:57
