I have a few Music videos which are Vob files and in the past they don't really play on my PC. So the other day i just changed the file extension from .VOB to .mpg and it played. Is it wrong to do this? I mean it played perfectly...so my question is because this sounds so simple to do...should i use some kind of software to do the conversion instead.
Thanks.![]()
Can you do it ? Obviously you can, because you did.
Will it work ? Yes, and no.
For simple playback you may have no issues at all. However it depends on how the VOB was created in the first place. Some lower end encoders will output directly to VOB files, without the actual DVD structure. In many cases these are little more than mpg files with a VOB extension.
If the source VOBs can originally from a properly authored DVD however, they could also contain other data, including menus, subtitles, multiple audio tracks etc. This extra data can cause playback issues and conversion issues later on. In this case you are better off using a tool called VOB2MPG to properly re-package the video and audio into mpg files.Read my blog here.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
2 audio streams converting VOB 2 MPG
By Harleyman in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 26th Sep 2009, 05:13 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 09:11 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
Converting VOB file to MPG
By weenie02000 in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2008, 13:58
Use
