I'm doing some edits of multi-cam concerts and the color correction included with the software is OK, but I need something advanced. I've seen some stand alone software that seems pretty competent and has features that match colors from scene to scene.
Can you recommend some plugins like this? Obviously, it'd be much easier to do it to the source files in the editing program than afterward on the an exported video. I use EDIUS Pro 5, but I'd be willing to go to an earlier version for the sake of plugin compatibility.
Normally one would log the good stuff, then color correct the bin then edit.
I'm trying to remember the plug-in but you can always hire a DaVinci
In the meantime here is the Google list
http://www.google.com/search?hl=en&rlz=1R2GZHZ_enUS336&q=color+correction+plugin&aq=0&...on+plug&aqi=g4
Here is a long list but I don't see what I saw demoed at NAB.
http://www.aeplugins.myleniumstuff.de/?cat=8Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
color correction in MeGUI
By codemaster in forum DVD RippingReplies: 1Last Post: 2nd Mar 2012, 20:56 -
mpg2 color correction?
By Mike99 in forum RestorationReplies: 74Last Post: 25th Oct 2011, 22:31 -
General Color Correction
By elmuz in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2011, 15:51 -
Increasing color depth and sampling for color correction
By poisondeathray in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2009, 09:06 -
Color Correction for DV
By bsuska in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 23rd Oct 2008, 17:24
