    Jul 2009
    Hello. I would really appreciate it if someone could help me. I have google all over the place for my problem and can't figure anything out. I have already lost 5 DVD's and realized I did't have to burn to DVD. I could have easily saved the files on my harddrive and then burn it if I wanted to (I know, stupid me). My problem is that the audio is way too fast. It's faster than the video. Please help me! Here is my log file:
    2009-07-21 12:43:49 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
    2009-07-21 12:43:06 Info Folder C:\Users\sylviaysaul\Documents\ConvertXtoDVD\Walk has been removed
    2009-07-21 12:43:05 Info BURN: WRITE SUCCESS: Disc written
    2009-07-21 12:43:05 Info BURN: Finalization Time 00:00:27 - Total completion time 00:13:59
    2009-07-21 12:42:38 Info BURN: Write finished in 00:13:32 - Finalization start here. Avg. burn rate 4.28
    2009-07-21 12:29:18 Info BURN: Lead-in burning time (mS) 0
    2009-07-21 12:29:06 Info BURN: Write started 2138464 sectors to write
    2009-07-21 12:29:06 Info BURN: Init success: DVD+R
    2009-07-21 12:29:06 Info BURN: Writing speed requested x4.0, effective x4.0
    2009-07-21 12:29:04 Info BURN: Available write speed: 16x, 12x, 8x, 6x, 4x
    2009-07-21 12:29:04 Info BURN: Media ID: RITEK-F16-01
    2009-07-21 12:29:04 Info BURN: Media type: DVD+R
    2009-07-21 12:29:02 Info BURN: Scanned files #24, folder #2 - total size 4378441728 b. (4.08 Gb.)
    2009-07-21 12:29:02 Info BURN: Inserted media type : DVD+R
    2009-07-21 12:29:00 Info BURN: Write started
    2009-07-21 12:29:00 ---- ***************** Encoding end **********************
    2009-07-21 12:28:58 Info Disc name: "Walk"
    2009-07-21 12:28:58 Info Burned folder: "C:\Users\sylviaysaul\Documents\ConvertXtoDVD\Walk \"
    2009-07-21 12:28:44 Info BURN: New media (DVD+R) inserted. Burning layer is ready to write
    2009-07-21 12:28:41 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2009-07-21 12:28:41 Info BURN: Drive has Serial ATA physical interface
    2009-07-21 12:28:41 Info BURN: New Drive selected : 2:1:0 - TSSTcorp CDDVDW SH-S203B SB01 [G] (Ata)
    2009-07-21 12:28:41 Info Total size 4175 Mb., Target size DVD5 4300 Mb., Occupation 97.11%
    2009-07-21 12:28:41 Info Conversion completed in 00:41:05
    2009-07-21 12:28:41 Info Rendering rate: 3.81 x Realtime
    2009-07-21 12:28:41 Info DVD duration (incl. menus) 02:36:36 (~ 9396 sec.) - rendering time 00:41:05
    2009-07-21 12:28:24 Info Generated duration 1153.80 sec., expected 1153.93 sec.
    2009-07-21 12:27:01 Info Chapter #4 start at 15:0.399
    2009-07-21 12:25:58 Info Chapter #3 start at 10:0.099
    2009-07-21 12:24:55 Info Chapter #2 start at 5:0.300
    2009-07-21 12:23:46 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2009-07-21 12:23:46 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
    2009-07-21 12:23:46 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 3770 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2009-07-21 12:23:46 Info Video processing: Fast linear (VSO) resampler (320*240)->(720*480)
    2009-07-21 12:23:46 Info Chapter sequences require 322 Mb. temp space
    2009-07-21 12:23:46 ---- ************ Source file #1 END DETAILS ************
    2009-07-21 12:23:46 Info AUDIO Stream #2 : Audio: mp3, 44100 Hz, stereo, s16, 128 kb/s
    2009-07-21 12:23:46 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 320x240 [PAR 1:1 DAR 4:3], 29.97 FPS
    2009-07-21 12:23:46 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2009-07-21 12:23:46 Info Logical file: C:\Downloads\Walk.avi - 1 file(s) 157 Mb.
    2009-07-21 12:23:46 ---- *********** Source file #1 BEGIN DETAILS ***********
    2009-07-21 12:23:46 Info Video bitrate 0/3770/9608 Kbps (min/avg/max)
    2009-07-21 12:23:46 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2009-07-21 12:23:46 ---- ======================= TITLESET #5 =======================
    2009-07-21 12:23:46 Info Generated duration 2011.77 sec., expected 2011.96 sec.
    2009-07-21 12:23:15 Info P-SDT buffer Underflow 1 times, 1501 bytes peak
    2009-07-21 12:23:15 Info 2 frames duplicated
    2009-07-21 12:22:19 Info Chapter #7 start at 30:0.298
    2009-07-21 12:21:24 Info Chapter #6 start at 24:59.998
    2009-07-21 12:20:30 Info Chapter #5 start at 20:0.199
    2009-07-21 12:19:34 Info Chapter #4 start at 15:0.399
    2009-07-21 12:18:39 Info Chapter #3 start at 10:0.099
    2009-07-21 12:17:43 Info Chapter #2 start at 5:0.300
    2009-07-21 12:16:29 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2009-07-21 12:16:29 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
    2009-07-21 12:16:29 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 3623 kb/s, pulldown: 23.976 -> 29.97 Fps
    2009-07-21 12:16:29 Info Video processing: Pad (Left:0 - Top:26 - Right:0 - Bottom:26)
    2009-07-21 12:16:29 Info Video processing: Fast linear (VSO) resampler (720*480)->(720*428)
    2009-07-21 12:16:29 Info Chapter sequences require 346 Mb. temp space
    2009-07-21 12:16:29 ---- ************ Source file #1 END DETAILS ************
    2009-07-21 12:16:29 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 192 kb/s
    2009-07-21 12:16:29 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 720x480 [PAR 1:1 DAR 3:2], 23.98 FPS
    2009-07-21 12:16:29 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2009-07-21 12:16:29 Info Logical file: C:\Downloads\Walk.avi - 1 file(s) 542 Mb.
    2009-07-21 12:16:29 ---- *********** Source file #1 BEGIN DETAILS ***********
    2009-07-21 12:16:29 Info Video bitrate 0/3623/9608 Kbps (min/avg/max)
    2009-07-21 12:16:29 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2009-07-21 12:16:29 ---- ======================= TITLESET #4 =======================
    2009-07-21 12:16:29 Info Generated duration 2955.76 sec., expected 2955.84 sec.
    2009-07-21 12:15:58 Info P-SDT buffer Underflow 1 times, 1260 bytes peak
    2009-07-21 12:13:44 Info Chapter #10 start at 45:0.197
    2009-07-21 12:12:37 Info Chapter #9 start at 40:0.398
    2009-07-21 12:11:30 Info Chapter #8 start at 35:0.098
    2009-07-21 12:10:23 Info Chapter #7 start at 30:0.298
    2009-07-21 12:09:15 Info Chapter #6 start at 25:0.098
    2009-07-21 12:08:07 Info Chapter #5 start at 20:0.299
    2009-07-21 12:06:53 Info Chapter #4 start at 14:59.999
    2009-07-21 12:05:31 Info Chapter #3 start at 10:0.199
    2009-07-21 12:04:08 Info Chapter #2 start at 5:0.400
    2009-07-21 12:02:37 Error This is the 25th audio discontinuity, turning off report of audio discontinuities
    2009-07-21 12:02:37 Info Stream #2 - Audio sync at 504.00 ms: 24.00 ms removed
    2009-07-21 12:02:37 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2009-07-21 12:02:37 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
    2009-07-21 12:02:37 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 3549 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2009-07-21 12:02:37 Info Video processing: Pad (Left:6 - Top:0 - Right:6 - Bottom:0)
    2009-07-21 12:02:37 Info Video processing: Fast linear (VSO) resampler (672*512)->(708*480)
    2009-07-21 12:02:37 Info Chapter sequences require 369 Mb. temp space
    2009-07-21 12:02:37 ---- ************ Source file #1 END DETAILS ************
    2009-07-21 12:02:37 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 192 kb/s
    2009-07-21 12:02:37 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 672x512 [PAR 1:1 DAR 21:16], 29.97 FPS
    2009-07-21 12:02:37 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2009-07-21 12:02:37 Info Logical file: C:\Downloads\Walk.avi - 1 file(s) 510 Mb.
    2009-07-21 12:02:37 ---- *********** Source file #1 BEGIN DETAILS ***********
    2009-07-21 12:02:37 Info Video bitrate 0/3549/9608 Kbps (min/avg/max)
    2009-07-21 12:02:37 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2009-07-21 12:02:37 ---- ======================= TITLESET #3 =======================
    2009-07-21 12:02:37 Info Generated duration 2119.48 sec., expected 2119.54 sec.
    2009-07-21 12:01:51 Info P-SDT buffer Underflow 1 times, 1260 bytes peak
    2009-07-21 12:00:03 Info Chapter #7 start at 29:59.998
    2009-07-21 11:58:52 Info Chapter #6 start at 25:0.198
    2009-07-21 11:57:46 Info Chapter #5 start at 20:0.299
    2009-07-21 11:56:40 Info Chapter #4 start at 14:59.999
    2009-07-21 11:55:27 Info Chapter #3 start at 10:0.199
    2009-07-21 11:54:06 Info Chapter #2 start at 5:0.400
    2009-07-21 11:52:39 Error This is the 25th audio discontinuity, turning off report of audio discontinuities
    2009-07-21 11:52:39 Info Stream #2 - Audio sync at 504.00 ms: 24.00 ms removed
    2009-07-21 11:52:38 Info Stream #2 - Audio sync at 504.00 ms: 24.00 ms removed
    2009-07-21 11:52:38 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2009-07-21 11:52:38 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
    2009-07-21 11:52:38 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 3513 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2009-07-21 11:52:38 Info Video processing: Pad (Left:6 - Top:0 - Right:6 - Bottom:0)
    2009-07-21 11:52:38 Info Video processing: Fast linear (VSO) resampler (672*512)->(708*480)
    2009-07-21 11:52:38 Info Chapter sequences require 346 Mb. temp space
    2009-07-21 11:52:38 ---- ************ Source file #1 END DETAILS ************
    2009-07-21 11:52:38 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 192 kb/s
    2009-07-21 11:52:38 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 672x512 [PAR 1:1 DAR 21:16], 29.97 FPS
    2009-07-21 11:52:38 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2009-07-21 11:52:38 Info Logical file: C:\Downloads\Walk.avi - 1 file(s) 370 Mb.
    2009-07-21 11:52:38 ---- *********** Source file #1 BEGIN DETAILS ***********
    2009-07-21 11:52:38 Info Video bitrate 0/3513/9608 Kbps (min/avg/max)
    2009-07-21 11:52:38 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2009-07-21 11:52:38 ---- ======================= TITLESET #2 =======================
    2009-07-21 11:52:38 Info Generated duration 1124.13 sec., expected 1124.19 sec.
    2009-07-21 11:52:15 Info P-SDT buffer Underflow 1 times, 1260 bytes peak
    2009-07-21 11:51:23 Info Chapter #4 start at 14:59.999
    2009-07-21 11:50:17 Info Chapter #3 start at 10:0.199
    2009-07-21 11:49:06 Info Chapter #2 start at 5:0.400
    2009-07-21 11:47:37 Error This is the 25th audio discontinuity, turning off report of audio discontinuities
    2009-07-21 11:47:37 Info Stream #2 - Audio sync at 504.00 ms: 24.00 ms removed
    2009-07-21 11:47:36 Info Stream #2 - Audio sync at 504.00 ms: 24.00 ms removed
    2009-07-21 11:47:36 Info Audio settings: Automatic With DTS -> AC-3 conversion
    2009-07-21 11:47:36 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, s16, 192 kb/s
    2009-07-21 11:47:36 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 3497 kb/s, frame compensation: 29.970 -> 29.97 Fps
    2009-07-21 11:47:36 Info Video processing: Pad (Left:6 - Top:0 - Right:6 - Bottom:0)
    2009-07-21 11:47:36 Info Video processing: Fast linear (VSO) resampler (672*512)->(708*480)
    2009-07-21 11:47:36 Info Chapter sequences require 322 Mb. temp space
    2009-07-21 11:47:36 ---- ************ Source file #1 END DETAILS ************
    2009-07-21 11:47:36 Info AUDIO Stream #2 : Audio: mp3, 48000 Hz, stereo, s16, 192 kb/s
    2009-07-21 11:47:36 Info VIDEO Stream #1 : Video: mpeg4, yuv420p, 672x512 [PAR 1:1 DAR 21:16], 29.97 FPS
    2009-07-21 11:47:36 Info Audio/Video file with 2 stream(s) - Playback order:1 - Queue:0
    2009-07-21 11:47:36 Info Logical file: C:\Downloads\Walk.avi - 1 file(s) 210 Mb.
    2009-07-21 11:47:36 ---- *********** Source file #1 BEGIN DETAILS ***********
    2009-07-21 11:47:36 Info Video bitrate 0/3497/9608 Kbps (min/avg/max)
    2009-07-21 11:47:36 Info OUTPUT ==> Resolution: FULL D1 [720*480], Format: NTSC, Aspect ratio: 4:3
    2009-07-21 11:47:36 ---- ======================= TITLESET #1 =======================
    2009-07-21 11:47:36 Info 2 Stream(s) found - est. duration 00:18:41.933, reference 00:18:41.933
    2009-07-21 11:47:36 Info Opening file "C:\Downloads\Walk.avi"
    2009-07-21 11:47:36 Info 2 Stream(s) found - est. duration 00:32:43.964, reference 00:32:43.964
    2009-07-21 11:47:36 Info 2 Stream(s) found - est. duration 00:48:27.838, reference 00:48:27.838
    2009-07-21 11:47:36 Info 2 Stream(s) found - est. duration 00:34:31.536, reference 00:34:31.536
    2009-07-21 11:47:36 Info 2 Stream(s) found - est. duration 00:18:12.191, reference 00:18:12.191
    2009-07-21 11:47:36 Info [ ] Multicore support in resize
    2009-07-21 11:47:36 Info Project size 4.17 Gb. (213 Mb. audio - 3.95 Gb. video)
    2009-07-21 11:47:36 Info [ ] Don't fix audio gaps
    2009-07-21 11:47:36 Info [ ] Engine Log
    2009-07-21 11:47:36 Info Encoding quality: High
    2009-07-21 11:47:36 ---- ****************** Encoding begin *******************
    2009-07-21 11:47:36 ---- **************** Menu settings end ******************
    2009-07-21 11:47:36 Info [x] Don't create title menu for single video
    2009-07-21 11:47:36 Info [x] Return to title menu after titleset playback
    2009-07-21 11:47:36 Info [x] Skip root menu initially
    2009-07-21 11:47:36 Info [ ] Play titles one after the other
    2009-07-21 11:47:36 Info [ ] Loop playback
    2009-07-21 11:47:36 Info [ ] Auto-start playback
    2009-07-21 11:47:36 Info Menu fit: Text size reduced from 16 to 16 in style "caption"
    2009-07-21 11:47:36 Info Menu fit: Text size reduced from 16 to 16 in style "title"
    2009-07-21 11:47:36 Info Menu fit: Text size reduced from 18 to 16 in style "caption"
    2009-07-21 11:47:36 Info Menu fit: Text size reduced from 30 to 16 in style "title"
    2009-07-21 11:47:36 Info Template: Black Mirror with video, contains 4 page(s), 17 customizable element(s)
    2009-07-21 11:47:36 ---- *************** Menu settings begin *****************
    2009-07-21 11:47:36 ---- **************** Burn settings end ******************
    2009-07-21 11:47:36 Info Default speed selected: Max
    2009-07-21 11:47:36 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2009-07-21 11:47:36 Info BURN: Drive has Serial ATA physical interface
    2009-07-21 11:47:36 Info BURN: New Drive selected : 2:1:0 - TSSTcorp CDDVDW SH-S203B SB01 [G] (Ata)
    2009-07-21 11:47:36 Info [x] Delete DVD folder after burn complete
    2009-07-21 11:47:36 Info [ ] Don't eject disc or open DVD folder in explorer, after burn complete
    2009-07-21 11:47:36 Info SAO setting: Automatic
    2009-07-21 11:47:36 Info [ ] Add original files to DVD (if possible)
    2009-07-21 11:47:36 Info [x] Burn result to DVD
    2009-07-21 11:47:36 ---- **************** Burn settings begin ****************
    2009-07-21 11:06:41 Info 36 Menu templates loaded.
    2009-07-21 11:06:38 Info BURN: 2 writer(s) found.
    2009-07-21 11:06:38 Info BURN: Loaded DLL "C:\Program Files (x86)\VSO\ConvertX\3\vso_hwe.dll" [3.2.6.409]
    2009-07-21 11:06:38 Info BURN: Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
    2009-07-21 11:06:38 Info BURN: Drive has Serial ATA physical interface
    2009-07-21 11:06:38 Info BURN: New Drive selected : 4:0:0 - TSSTcorp CDDVDW SH-S203B SB01 [H] (Ata)
    2009-07-21 11:06:38 Info BURN: Using Patin-Couffin driver Version , Internal revision 37 Async. Access mode
    2009-07-21 11:06:37 Info Supported instruction set: sse3
    2009-07-21 11:06:37 Info Number of allocatable threads: 2
    2009-07-21 11:06:37 Info Tuning Performances for AMD Athlon(tm) 64 X2 Dual Core Processor 6400+ with 2 core(s) CPU
    2009-07-21 11:06:36 Info System default language : English (United States)
    2009-07-21 11:06:36 Info User default language : English (United States)
    2009-07-21 11:06:36 Info Version : 3.7.2.188
    2009-07-21 11:06:36 Info ExeName : C:\Program Files (x86)\VSO\ConvertX\3\ConvertXtoDvd.exe
    2009-07-21 11:06:36 Info OS : Microsoft Windows Vista Ultimate (Build 6002: Service Pack 2)
    2009-07-21 11:06:34 ---- ******************** Log session start 2009-07-21 11:06:34.260 PID 3984********************
    I would really appreciate with all my heart if someone can help me solve this frustrating problem. Thank you and God bless. Let me know if you need additional info. Thanks again.
    Audio input may have been VBR.
    Aug 2013
    Sydney
    Just for the record - if you did want to burn to DVD to see results without wasting discs, I find using DVD-RW (Rewritable) discs very useful. Imation brand has been the best for me. And Convertx has no problem with them.
    I use them if I don't want to sit at the computer and they can be used over and over again.
