Hello, it's my first post on this forum !![]()
Here is my problem, I've got a lot of videos with background noise in .mov format.
I have done a ruby script to automatise all steps.
But i'm blocked on this step :
I want to demux files, treat sound with an audio processing program, and remux audio with video.
All that stuff on Mac OS and scriptable (so in command line (ffmpeg, HandBrakeCLI...)) :P
I don't find a good solution, so if anybody can help me, it would be nice !
Thank you !
Fixing noise would have to be done in an Audio editor such as
Bias, Audacity, or Amadeus II. Then a new AIFF file generated
from the clean file. Then that File muxed back in with the video."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks for answers !
I already did it with Amadeus Pro, but it's not in CLI.. And that's the prob.
I tested to do that in Apple Script with a soft called UI Browser which can normally translate actions of any programs in Apple Script, but the script doesn't work well. And, moreover, i don't know if we can pass parameter to an Apple Script...
I'm a blocked..
It works now ! I used UI Browser in the good way !
So now, I scripted all the workflow to demux and correct the background sound in Applescript.
Now I have to remux corrected audio and video, certainly in ffmpeg.
If you are intrested to see the script, tell me and i post it !
Since the answer of "Google how to use it" leads to this forum, here is the command line to demux:
The command lines for demuxing are:
-> to get the audio
ffmpeg -i input -vn -acodec copy output
-> to get the video
ffmpeg -i input -an -vcodec copy output
The extension for "output" is important: if you want you video embedded with an avi header, put ".avi"; if you want your aac audio readable on an iPod, put ".m4a"...
Note that Google only gives answers if some put them sometimes so if you know them, put them.
Demux/Mux Tool
By mltwitz in forum DVD RippingReplies: 3Last Post: 7th Dec 2010, 10:39 -
Demux and Mux question
By danielmak in forum MacReplies: 1Last Post: 14th Feb 2010, 09:56 -
Trying to mux / demux
By GLE3 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2009, 12:07 -
Mux/Demux Bug
By cefn in forum Video ConversionReplies: 3Last Post: 3rd Jun 2008, 13:09 -
Demux & Mux
By homantam in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2007, 08:51
