my video is playing way too fast and i want to slow down .
Results 1 to 13 of 13
Before you do something silly to the video, are you sure the video is the problem.
I would start by checking the playback in a different player. Media Player Classic, VLC or The KM Player are all good options. Media Player Classic (MPC) is the least intrusive.
You may find your problem lies elsewhere.
If the problem is with the video itself then you will have to provide a lot more detail to get a useful answer. Start with posting a MediaInfo Tree output to tell us exactly what you have.Read my blog here.
Yes, i have tried with any video player and the video is playing like 3second pr sec .My video is mpeg2 and every time i try to converted it to another format the video saved in high speed and leaving one third of time.That file is ripped form a vcd and it play fine on a dvd player.But it seem to be screw up when i try to copy to pc.I think a video speed reducing software might fix the problem but i don't know one.
Opps sorry ,here's the info
video stream
9000kbps , 320*240(4/3),25 fps,mpegvideo(version2)
audio stream
128kbps , 48.0KHz,2channels,mpegaudio(version 1) -
Something is screwy with the file. The bitrate is way too high for VCD and the resolution is wrong for VCD. I suspect that the ripping process has damaged the file, and there will be little you can do to fix it other than re-rip it. It thinks is has a framerate of 25 fps, which is PAL standard, however the resolution is neither PAL nor NTSC (or in fact VCD at all).
How was this ripped ?Read my blog here.
Yeah, I'd suspect an improper conversion from DAT to MPG.
What did you do, just rename the DAT file as MPG? My suggestion is to start over and put it on the hard drive correctly. I use the old free version of VCDEasy.But it seem to be screw up when i try to copy to pc.
Not if it's VCD, it's not.My video is mpeg2
I don't. I think starting over and doing it right will fix the problem.I think a video speed reducing software might fix the problem -
No,what i mean is that i downloaded this video file form internet in flv format and converterd into vcd format by using "quickmediaconverter" and them i write the file into a empty vcd which is seam to be reading correctly in home dvd player .But when i try to copy back from that disk into pc the video play faster then the sound .Same happen when i put it into my mp4 player.I've tried with video converter like any video converter or next video converter to convert it to avi or any other format but it doesn't works and instead the video become smaller about one third of original size (got the whole clip but it play faster ).Since the original file form internet is deleted this file is only one i got and no more back up file.Is there any way to fix it.
Open your video in VirtualDubMod. Go to Video -> Frame Rate... In the Source Rate Adjustment field enter whatever frame rate you need to get the audio and video in sync. In the Frame Rate Conversion field enter the desired output frame rate. Save or frame serve.
Try Super Video Converter, it rules (imo) and does everything you want it to. http://www.erightsoft.com/SUPER.html
Womble mpeg video editor I get "No disc or disc error"
By pumpkinslion in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2010, 19:32 -
MPEG Layer 2 video file, is it an editor friendly file type?
By ferran275 in forum Video ConversionReplies: 18Last Post: 16th Apr 2010, 23:41 -
MPEG Editor like Womble but with 2 video tracks?
By greymalkin in forum EditingReplies: 26Last Post: 19th Jan 2010, 06:52 -
Sophisticated MPEG-2 Editor
By neumannu47 in forum EditingReplies: 12Last Post: 1st Jun 2008, 01:33 -
MPEG 4 editor
By spikey-k in forum EditingReplies: 2Last Post: 23rd Jul 2007, 05:39
