Here's my problem.
I have a pal formated movie that is 16.9 and 2.35.
I've made a subtitle script , timed it ect.
Everything looks fine. But I burned it to dvd and now it seems it's formated for 16.9 tvs. I don't have a 16.9 tv and my original file of 2.35 works perfect on my standard tv. Now it seems letterboxed on my 4.3 tv.
So how do I set it up to keep it 2.35 on my tv? Menu and movie. Do I make my menu in 4.3? I don't want my movie in fullscreen. I'm at a loss?? Or dumb?? you choose![]()
Your Project should have been started as a 4:3 project.
The fact that it is letterboxing on your TV means
that somewhere either a pulldown flag wasn't set correctly
( in the Project Preferences) or the asset wasn't encoded
with the correct pulldown.
I would start with the project first, as that is the easiest.
Verify by crating a new project that the project is 4:3.
Then add the asset, and highlighting the timeline,
check the Inspector on the timeline to see if a flag is set
(for 16:9 letterbox)."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks for the tip.Originally Posted by terryj
I'm still at a loss. I did exactly what you said and my finshed project was still jacked up.
Here's my whole step by step, Maybe you can find where I'm wrong?
DvD-R via Mac the Ripper
Mac the Ripper settings to Extract all streams. M2v, 2 audio tracks.
Made a sub-title script in Jubler saved as .stl
Opened up DVDSP
In Prefs (Project SDDVD Pal), (General-Display Mode 4:3), (Encoding-16.9 two pass VBR bit 6.0-8.0)
added my assets, Checked my m2v in DVDSP from asset box it shows it's 16.9 ( doesnt say letterbox)
But if I check in timeline is doesnt say anything 16.9 ect...
But if I inspect the track one box see pic below. It has a display mode that can be changed. Do I have to change this to 4.3 for proper playback on standard tvs? I haven't change this box before when making the final dvd.
Could this be causing the problem?
Ok, I've figured it out. Now I have a problem with playback.
All I did was Mux the M2v and 2 audio files. I've got the 4:3/16.9 figured out but after I muxed the 3 files together and ripped to dvd. During playback it kind of sputters. I've noticed this before Using MovieGate. If you don't re-encode it sputters but if you choose to re-encode I notice it goes theu a little AC3 fix. And after it does the whole AC3 fix and muxing it plays flawless.
Is this a common problem with AC3 files? I know quicktime stills has a problem with decoding. Is this another problem in DVDSP as well? If you use the viewer in DVDSP it plays fine. Mux them together and it's another story???
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 21:06 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Final Cut Pro 7 Studio Settings for Panasonic HDC HS-100
By TNester in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2010, 14:03 -
Vegas Pro 8 user with questions about program (and possible camera settings
By chuchunezbie in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2009, 17:32 -
DVD autoplay settings in Pinnacle Studio 12
By lrios in forum Authoring (DVD)Replies: 2Last Post: 10th Feb 2009, 13:09
