I'm trying to covnert a DVD to a WMV
It worked fine when it compressed down to about 800 meg, but I want to keep it in the original quality and not compress it
I can't find ANYWHERE in the program to adjust the compression in terms of the output file.
Unless a 800 meg (from 4.4 gig vob) is not compressed (doubt it)
Any ideas?
-It was on the WM9 profile (i believe) at 95% picture and 75% or so audio.
Going to try the WM9adavanced later to see how that is.
Well you can't keep it in original quality AND reconvert to wmv as reconverting will always mean some quality loss.
But try change the picture value to 100% and you should get very good quality.
Or use hdconverttox to convert to wmv and you can configure more wmv settings.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 11:54 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
