I have pineapple express on the laptop and i can watch it fine on here with no problem but when i burn it onto a dvd it works fine, sound and video perfect but just one scene the sound will jump ahead or slow down. anyway i can fix that? is it a problem with burning? i use Cheetah dvd burner, any suggestions to a different burner? i can get whichever.
thanks.
hi and welcome to the forum. try to be a bit more informative in your posts. detailed specifics will help answer questions.
what format is the video in on the laptop?
what did you use to convert it to dvd format?
what brand of dvd blank did you use?
what are you playing the dvd with? -
I'm sorry, haha, never really described a video problem.
The format is avi on my laptop and then i convert it with the same program that burns it. I use tdk blank dvds but i also have Sony i can use. and i am using my playstation 2, but i play dvds on that all the time.
Windows Live Movie Maker - Sound Not Sync'd
By iHackMario in forum EditingReplies: 2Last Post: 27th Aug 2010, 17:44 -
sound gets delayed after playing 15 minutes
By mihai-gdm in forum Video ConversionReplies: 4Last Post: 28th Jan 2010, 21:46 -
VCD to PSP - Audio out of sync in last five minutes
By BozQ in forum Video ConversionReplies: 6Last Post: 2nd Apr 2009, 22:43 -
video file out of sync after 20 minutes
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2009, 04:21 -
burn 120 minutes movie in 1 CD?
By hackerzlab in forum Newbie / General discussionsReplies: 18Last Post: 9th May 2007, 10:16
