Hi,
the media player is connected via YrPrBr (YUV) cabling to the HDTV.
From my point of view, i don't see any differencies if i deinterlace the video first or send it to the TV directly. So i think i could leave it as it is.
Results 31 to 38 of 38
Just use Staxrip, pick size/bitrate or do a 1 pass or 2 pass encode, Staxrip produces avi(divx) compatible files that can be played on any divx certified/xvid player.
It has deinterlacer and sharpness options, it even has a compressibility test like autogk if you're not sure which bitrate to pick.
Tools like avi.net, AutoGk or StaxRip were made having that in mind and have been thoroughly tested by "everyone" so that us (users) dont have to go through endless days finding what works.
I would recommend avi.Net but it doesnt accept avi/dv as inputI love it when a plan comes together! -
Hi,
thanks for your reply. But if i don't need to deinterlace or sharpen the video, i just can do a fast compress via VirtualDub, isn't it?
Greetings -
Not if you're resizing vertically, you can't. Otherwise, why not try and see for yourself?
Yeah, good question.
I will try to create several files with identical compression but different deinterlacing and i will see what happens. I don't have to resize the files. I only want to make them compatible to my media player and save disk space without losing to much quality
By the way i have some other questions about virtualDub
1. What's the difference between Fast Compress and Normal Compress in the Video Settings?
2. If i capture my DV-Videos with VirtualDub, wouldn't it be better to set the compression format via capturing? Actually i have a DV-Video with 13 GB per hour. Wouldn't it be easier to do a direct XVid-Capturing?
Or isn't that possible in realtime? -
Fast Recompress leaves the video in the colorspace (typically YUY2 or YV12) it comes from the source and passes it to the chosen encoder. Normal Recompress converts the source video to RGB then passes RGB to the encoder. Fast Recompress gives better quality.Originally Posted by foxhunter
You are more likely to drop frames if you compress while capturing. You would have to use Xvid at it's fastest settings (Reat-time quality preset) to do this. You won't get as good compression.Originally Posted by foxhunter -
You should avoid colorspace conversion whenever possible. Use VirtualDub in Fast Recompress mode if you're not filtering.
Reading Encoding Settings
By dogar in forum Video ConversionReplies: 5Last Post: 8th Dec 2011, 06:30 -
sony vegas avchd to dvd -project settings confusion
By baross in forum EditingReplies: 6Last Post: 11th Aug 2010, 09:20 -
Encoding to WAV (Channel Confusion)
By RabidSmurf in forum AudioReplies: 9Last Post: 11th Jan 2009, 08:06 -
AutoGK Settings: Frame Rate Confusion
By Tom Saurus in forum Video ConversionReplies: 3Last Post: 30th Sep 2007, 05:18 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
