Can anyone please help me by explaining so simply even an idiot like me can understand?
I haven't got a clue what I'm doing and I'm new to OSX too!
Brian
Do a full disc extraction with MTR.
Add the resulting VIDEO_TS folder to the VIDEO_TS folders setting in Toast's Video window. Customize what you want on the copied disc (if you don't want to duplicate everything). Doing any customizing means the resulting DVD will not have a menu.
Burn your DVD if it fits your disc. If it doesn't fit choose Save as Disc Image. Then choose the resulting .toast file using the Image File setting in the Copy window. This will activate Toast's Fit-to-DVD feature for burning to a single-layer disc. -
Frobozz, you assumed that the OP is talking about a commercial DVD. If that is what they are talking about then there might be one more app and step they need. DVD2oneX
Also, we don't know which version of MTR they are using which could be a problem.
Read the following for a little more help:
http://www.ripdifferent.com/forum/viewtopic.php?f=34&t=3958
DVD ripper for Mac
By tee jay in forum DVD RippingReplies: 1Last Post: 28th Feb 2012, 10:48 -
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Is there a dvd ripper for Mac?
By reddeviljp in forum MacReplies: 9Last Post: 15th Aug 2008, 03:10 -
Burning dual layer dvd-r from mac the ripper
By alforra in forum MacReplies: 11Last Post: 18th Apr 2008, 22:08 -
Mac the Ripper help
By spunkyc in forum MacReplies: 6Last Post: 12th Dec 2007, 20:25
