I can run Avi-MuxGUI in compatibility mode XP SP2 on Windows7 however when you open the settings window it is not resizable and only the left hand side of the window is visible. Any workarounds?
EDIT: Problem solved
I have solved the problem of running avi-muxGui version 1.17.1 on Windows7
1. Under compatibility use XP SP2 and turn off disable visual themes
2. Edit the file gui.amg.xml
3. Change the Settings window width and height to the following settings if you have a 16:9 display.
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE GUI SYSTEM "avimuxguiconfig.dtd">
<gui>
<file_information></file_information>
<settings_window>
<window_position>
<left>159</left>
<top>69</top>
</window_position>
<window_size>
<width>840</width>
<height>640</height>
</window_size>
</settings_window>
<chapter_editor>
<tree_default_title_languages>eng</tree_default_title_languages>
<default_save_extension>mkc</default_save_extension>
</chapter_editor>
<ebml_tree></ebml_tree>
<output>
<default_file_name_source>3</default_file_name_source>
</output>
<riff_tree></riff_tree>
<main_window>
<source_files>
<lowlight>1</lowlight>
<highlight>1</highlight>
</source_files>
<window_position></window_position>
<window_size>
<width>800</width>
<height>600</height>
</window_size>
</main_window>
<general>
<finished_muxing_dialog>1</finished_muxing_dialog>
<overwritedlg>1</overwritedlg>
</general>
</gui>
Results 1 to 1 of 1
avi.net backing up Iron Man 2 DVD>divx audio problem (SOLVED)
By crazifunguy in forum Newbie / General discussionsReplies: 7Last Post: 31st Oct 2011, 23:11 -
UBCD5 - Can Windows7 be wiped with it?
By ranchhand in forum ComputerReplies: 4Last Post: 11th Feb 2011, 14:11 -
nero and windows7 help
By RBASH in forum ComputerReplies: 11Last Post: 13th Jan 2010, 16:28 -
Windows7 & True Image
By beam_brandon in forum ComputerReplies: 1Last Post: 23rd Sep 2009, 05:08 -
How to join AVI. .. output size? delete mods problem solved?
By chocolate_brownie in forum EditingReplies: 9Last Post: 27th Jul 2007, 14:51
