I have
Adobe Premiere Pro
AE CS3
Vegas Movie Studio Platinum 9.0
My system:
AMD Phenom 8450 Triple Core
2 GB of Ram
GeForce 9600 GT 512MB
Plenty of HD space
When I use it in Vegas and hit the EDIT button it gives me '...an Open Gl error occured while attempting to load the frame (Fragment shader at -1
I'm not sure why it won't work. The tutorial video on Red Giants site looked like it was an easy to use color corrector but if I can't get it to work on ANY of the NLE's then I'm open to other suggestions as far as color correction software goes.
First though, any thoughts on why this is happening?
I should mention that after pushing the EDIT button multiple times I sometimes get a frame to work with. The effect looks as though it's been applied but when rendering it doesn't and the image is all black or red. I also tried TOON IT from Red Giant Software and couldn't get it to work. I've tried their support but they aren't good with getting back to people it seems.
Smile
Smile -
Vegas : Red Giant only supports Vegas Pro, not Platinum, and only for Magic Bullet Looks 1.2 and Quick Looks 1.2. Also, Quick Looks is supported in Vegas Pro 8, and Look sin 7 and 8. 9 is not officially supported.
The Magic Bullet Suite 2008 product isn't supported in Vegas at all.
Premiere Pro is supported in Version 2, CS3 and CS4. After Effects is supported fully for CS3 and CS4 (Windows only - CS3 for Mac) and partially for version 7.
You don't say which version of Premiere Pro you are using, or what problems you are having with Premiere or After Effects.Read my blog here.
I have Premier Pro CS3 and a trial version of After Effects CS4.
What is happening is when I try to apply the color correction of Looks to video, it will not open the 'looks builder' due to an Open GL error. After several attempts of clicking the edit button it WILL open the builder and while the first frame of the footage has the filter/effects applied, the rest is black or red only (No video). When rendering, it renders it all blank.
I asked a friend to try it with After Effects CS3 and he has the trial working fine.Smile
Smile -
A little light reading
http://toolfarm.com/phorumNew5/read.php?14,5081,page=2Read my blog here.
Did a read through.
I don't have any graphics applications running at the same time. The Nvidia panel doesn't load on start up. I start the application myself when needed. Still not having any success.Smile
Smile -
beavereater, your signature size and animated image is in violation of our rules:
Please correct this ASAPSignatures
Max 3 lines text using font size 12(bbcode font=Normal) or smaller and using forum width 680 pixels.
Max image size 400x60 and max file size 10kbyte.
No animated images and only gif,jpg or png images.
Moderator redwudz
Alternative video filter to Magic Bullet Looks\Colorisma
By kingo'mountain in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2010, 15:14 -
Anyone using Magic Bullet Looks Suite 1.1 to 2.1?
By cooldude859 in forum EditingReplies: 0Last Post: 7th Jan 2010, 03:31 -
Sony Vegas 8.0c (build 260) crashing while rendering, using Magic Bullet
By tranzadikt in forum EditingReplies: 0Last Post: 6th Dec 2008, 14:05 -
Troubles with 16:9 and Magic Bullet in Compressor
By ehmjay in forum MacReplies: 1Last Post: 30th Mar 2008, 14:46 -
Magic Bullet for 50i HDV
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Mar 2008, 04:34
