  1. Plz help me to solve the following problems
    Suggest a converter for m4a to AAC
    I need to trim the container present in m4a file and extract the part which have adts headers?
    Is MP4 and m4a different ?
    Feb 2004
    Region 2
    This one helped med:
    https://forum.videohelp.com/topic370467.html
    See b66pak's reply:
    try this:
    demux the neroaac encoded file to raw using mp4box (is in megui>tools>mp4box folder):
    mp4box -raw 1 myaudiofile.m4a
    you wil get an .aac file
    now remux it:
    mp4box -add myaacfile.aac -new remuxed.m4a
  3. Thanks for the replay!
    But i notice the files have sampling frequency 8kHz,11025Hz,12KHz,64k,88200Hz,96k failed while i use nero Encoder
    To create an M4a for this config:: what will i do?
    Feb 2004
    Region 2
    I am not quite shure what your problem is, or what you aim to do.
    In which PC-application, or standalone player, or whatever, do your m4a files fail? What is the purpose of stripping off headers, and convert from Mp4 container to Raw (containerless) aac files Why are the samplingrates 8-96KHz an issue
    Please explain some more
  5. i am on the via to save some disk space by converting wav and Mp3 to heaac and try all possible options
    Feb 2004
    Region 2
    If your audio is already aac/m4a, at 128Kbps, there is really not much space to save, by converting to aac at 64Kbps or similar. If your source audio is at say 256Kbps or above, their might be some space to gain, especially if you have a large number of files.
    But then again, you leaves us in the dark here. Why do you want to save space? To squeeze a single movie into a 2GB standalone MP4 player? Or maybe to squeeze 300 movies into a 200GB harddisk?
    I suggest you try MeGui as stated above, and then start a new thread, if your source file(s) gives you trouble.
  7. Banned
    Jul 2009
    Use -q 0.25 with Nero and you'll be surprised with the shitload of space you can save while preserving quality. Just avoid using HE for any music with sharp, high-freq instruments.
