I have a 5.7 GB video (in a VIDEO_TS folder on hard disk) which I would like to shrink to fit on a DVD5. I tried DVD Shrink 3.2 but it tells me "DVD is too big ..., make sure to set compression to automatic" (which it was set to from the beginning). Any advice appreciated. Leo
Results 1 to 11 of 11
Hit the analyze button and it should make it to where it will fit.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Hitting the Analyze button gives "Analysis of this DVD is not necessary, because either no compression was applied, or the compressed parts have already been fully analyzed". When I do Backup ... continue anyway, encoding is done but with zero compression. Could the fact that this is a folder on the harddisk and not a DVD be the problem?
If that still fails, give DVD Rebuilder a try.
Read my blog here.
DVD Rebuilder says: "Error. Illegal video GOP size. Possibly encrypted source. Aborted." Same result with the original source and after running it through fixvts. And DVD Shrink still produces a noncompressed .iso file.
Thank you for your time. -
This is a backup of a DVD which I made a year ago. Unfortunately I don't remember how I ripped it then. The original is not available any longer since my five year old has trashed it.
Alternatively I still have two files, .i00 and .i01 of the movie, but no idea how I might proceed these to restore the movie. Thanks again for listening, Leo -
Without the original to re-rip I don't think there is much you can do.
Donadagohvi (Cherokee for "Until we meet again") -
Do you also have a .mds file ? It should have been created at the same time as the .i00/.01 file.
If so, use the File -> Open Disc Image option in DVD Shrink and see if you can open the image. If you don't have the .mds file then I suspect you are SOOL.
(This also assumes the image files you have contain the entire disc. You don't say how big they are)Read my blog here.
I do have the .mds file. DVD Shrink tells me "Error ... Failed to open file <path>\*.i00" (Path is correct though). The image files are 4 and 2 GB, so should contain the entire disc.
Looks like something has gone awry. So let's go buy the disk again.
Thanks to both of you for your help.
what to do after shrinking this video....
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2011, 08:05 -
shrinking the size of a video
By m005k in forum Video ConversionReplies: 2Last Post: 3rd Jun 2010, 14:35 -
Shrinking Down a Video
By niteghost in forum Newbie / General discussionsReplies: 8Last Post: 12th Aug 2009, 06:58 -
video size keeps shrinking
By gally56 in forum Authoring (DVD)Replies: 1Last Post: 15th Apr 2008, 08:01 -
Shrinking 5.2 GB of video
By moviebuff2 in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2008, 11:43
