I have a bunch of files that have been encoded in a same way as this file hire:
Link to the small preview fiile!
And I would like to cut the crap out. So I tried to do this in virtualdub but it said that the videos are using unrecognized algorithm & it cant direct stream copy it.
Is there any other software I can use to cut those files?
File info:
Code:Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video #0 Codec : MPEG-4 AVC Codec/Info : MPEG4 ISO advanced profile
this program was able to do it, but it said the video is usion B frames as a referance so I cant use this program.Originally Posted by olyteddy
It asks you if you want to use a certain mode at the beginning dialog, say yes.Originally Posted by Information
There is no frame accurate h.264 editor. If you want frame accuracy, you will have to re-encode or at least reconstruct the GOP and append manually -
Alternatively, one can convert (not re-encode) to AVI with AVC2AVI and proceed to do frame accurate editting with VirtualDub. If B-pyramid is used, it will delay by however number of B-frames in the beginning, so audio must be adjusted, or completely avoid B-pyramid.
cut video and save as direct stream copy
By supercain in forum EditingReplies: 47Last Post: 8th Sep 2012, 10:32 -
No direct stream copy in vegas pro 11?
By supercain in forum EditingReplies: 13Last Post: 18th Dec 2011, 03:10 -
Direct Stream Copy of Panasonic MTS files
By Bjerner in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 16:03 -
MKV to AVI direct stream copy problem...
By zovx in forum Video ConversionReplies: 26Last Post: 25th May 2011, 09:14 -
Direct Stream Copy for All Formats
By bigMach™ in forum EditingReplies: 10Last Post: 11th Jun 2008, 14:02
